where's the fuse box??? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 07-04-2010, 05:46 AM Thread Starter
Date registered: Jul 2010
Hi all, i'm a new user of this forum.
I have a 2008 CLK 320 CDI Someone could explain to me where's the fuse box in the engine compartment???
I know it's a really stupid question but i can't find it...
bilbobaggins is offline
post #2 of 8 (permalink) Old 07-04-2010, 08:59 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 399 Post(s)
Up at the firewall (bulkhead) on the driver's side you will see a splash panel held by 2 plastic fasteners. Turn these 90 deg. and remove the panel.
Underneath you will see:
a) reservoir for the braking fluid
b) engine bay fusebox, under a latched cover.
Inside, it looks a bit of a mess, like this:
note: my car is RHD so the fusebox is on the other side to US model CLKs.
keyhole is offline
post #3 of 8 (permalink) Old 07-04-2010, 11:07 PM Thread Starter
Thank you very much keyhole, I will take a look for it today.
What a mess in there!!!
I'm looking for fuse #64 because i have changed Comand with a Kenwood DNX7200 and i'd like to re-enable clock/date menu to set it at the right time.
post #4 of 8 (permalink) Old 07-05-2010, 12:18 AM Thread Starter
should i unscrew the two bolts to open it?
post #5 of 8 (permalink) Old 07-05-2010, 12:55 AM
Date registered: Nov 2009
Vehicle: Clk 350
hi there is also a sam box in the back in the trunk and it also has fuses in them
moh1122 is offline
post #6 of 8 (permalink) Old 07-05-2010, 04:18 AM
keyhole's Avatar
Quoted: 399 Post(s)
Yes, your f64 is in there. Bottom left in my pic, i think. 10A, red.
keyhole is offline
post #7 of 8 (permalink) Old 07-05-2010, 04:25 AM
keyhole's Avatar
Quoted: 399 Post(s)
Wow! Is that a W209? .... or a W208?
Anyway, it looks like that's the only way in to that box. Mine (2004 CLK) has quick-release clips.
keyhole is offline
post #8 of 8 (permalink) Old 07-06-2010, 05:42 PM
jhs003's Avatar
Date registered: May 2010
Vehicle: 1997 S420
I don't know if this will help, but here is a scan of my wife's 2007 CLK 350 fuse box guide.
Name:	CLK 350 fuse box (2).jpg
ID:	317879   Click image for larger version
Name:	CLK 350 fuse box.jpg
jhs003 is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
  • Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
    Fuse positions in Fuse Box SG280SLC R/C107 SL/SLC Class 4 11-24-2013 04:02 AM
    Fuse box, fuse carrier for AC blower caved in hariratan W124 E,CE,D,TD Class 9 01-20-2013 04:43 PM
    Window wont roll up, Diagram of fuse box, which fuse is for the power windows? gpacheco101 R/C107 SL/SLC Class 8 03-09-2010 07:49 AM
    Small black box with Blue & White fuse in front of fuse box??? soltek W201 190-Class 2 09-14-2008 10:46 PM
    1985 300SD inline fuse from fuse box? hanknows W126 S,SE,SEC,SEL,SD,SDL Class 1 12-18-2007 02:26 AM
