Transmission flush done and now car wont drive at all - Mercedes-Benz Forum
post #1 of 30 (permalink) Old 12-21-2009, 11:12 PM Thread Starter
pacboy22's Avatar
Date registered: Oct 2007
Vehicle: 2003 clk500
Send a message via AIM to pacboy22
Exclamation Transmission flush done and now car wont drive at all
Im in desperate need of your guys help i had that dreaded valeo radiator that caused a leak into my transmission i have a 2003 clk500 68k miles and the car recentyl started kicking so i paid 800 dollars got my radiator changed and flushed of course changed the transmission flued because apparently there was about 2 quarts of fluid left most of it burned it looked like and there was tiny tiny particles of metal there and after all that was done everthing was changed and put back on the car wont drive at all it will go to P R N D but wont move from its place and not only that the automanuel doesnt work on the odometer it doesnt show the gears being changed im scared that they used non mercedes recommended ATF but even so lets say they didnt would that cause the car not to drive at all can somebody please help me on this situation ive spent alot of money already on this car and could it be electronic issue computer needed to be reprogrammed im sorry for such a long post but i had to leave the car overnight to have it taken apart tomorrow morning if somebody maybe could point me the right way so i dont have to shell out more money and be robbed and schemed because im not knowledgeable in this area any help would be apprecaited thanks in advance guys ...
pacboy22 is offline
post #2 of 30 (permalink) Old 12-21-2009, 11:30 PM
eric242340's Avatar
Quoted: 296 Post(s)
Did the transmission work OK before this repair? If so is there enough ATF in the Tranny? But burnt fluid with bits of metal does not sound good.
ERIC.
eric242340 is offline
post #3 of 30 (permalink) Old 12-22-2009, 12:09 AM Thread Starter
pacboy22's Avatar
Thanks for the quick reply..transmission was ok not great it was slipping from 1-2 k rpm range but it was driving decent and i belive they put 7 or 8 bottles but i dont think it was mercedes approved ATF could that make the car not move at all because i dont now and they can mess with my head and tell me tranny is gone fully but i brought the car in working condtion and now its not working at all i dont know what to do
pacboy22 is offline
post #4 of 30 (permalink) Old 12-22-2009, 12:19 AM
eric242340's Avatar
Quoted: 296 Post(s)
OK two questions here, what color was the fluid that they drained out? Pink/Red/Clear?
What fluid did they put in exactly?
ERIC.
post #5 of 30 (permalink) Old 12-22-2009, 12:29 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Water in the transmission fluid -- even a little -- can damage and ruin the AT and the longer you let it go the worse it is. However, the fact that the display is not registering the movement of the gearshift suggests it is indeed something electrical. Personally I'd start by seeing if any codes are stored and then open up the console to check the shifter electronics.
Good luck with it.
Check Codes is offline
post #6 of 30 (permalink) Old 12-22-2009, 12:32 AM
eric242340's Avatar
Quoted: 296 Post(s)
Good luck with it.
Hy Greg, you are correct and that is why we need to know what color the fluid was. If pink then water has indeed got in.
ERIC.
post #7 of 30 (permalink) Old 12-22-2009, 06:43 AM Thread Starter
pacboy22's Avatar
The color of the fluid was actually brownish/blackish from being burnt that what the guy said and he put it some regular pennzoil i think it was and it was red color he said its fine this one i use it on my car to he has a 1994 sl500 .. but my concern is how did the car go from perfect driving condition except for a slight hesitation between gear changed to not driving at all from even the wrong oil change the car no longer kicked when i switched gears and everyteime i shifted and pressed on the gas rpms went up but the car didn move i put it to automanual and the display didn change from d to 1 to 2 to 3 and 4 he himself got a lil stumped at that thanks for all your help guys
pacboy22 is offline
post #8 of 30 (permalink) Old 12-22-2009, 10:07 AM Thread Starter
pacboy22's Avatar
i just checked an article online and it said that if you drain the atf that was burned and put new fluid the tranny will no longer work it will only work on that old burned fluid for and X amount of time till it dies
pacboy22 is offline
post #9 of 30 (permalink) Old 12-22-2009, 10:08 AM Thread Starter
pacboy22's Avatar
basically thats the only fluid that it will run on till it dies...could that have some truth in it..i have spend my last pennies on this car already and new tranny will take me a while to save up for i really need help thanks in advance
pacboy22 is offline
post #10 of 30 (permalink) Old 12-22-2009, 10:24 AM
Date registered: Mar 2009
I need some help fellas, I have a 2004 CLK 320 and in the last couple of days I am stopped at a stop light and when I step on the gas, the car sputters before taking off. what could that be from ? I would appreciate any feedback
dabu260 is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
    So your car wont go in reverse & you wonder if a transmission out of a 190E will fit Tedd300DT W202 C-Class 11 05-15-2016 04:46 PM
    Starting Problems - Car wont start/starter motor wont stop winding. EnzedSurfer W210 E-Class 13 05-23-2012 03:26 PM
    BG Transmission Flush fangtl W210 E-Class 4 07-13-2008 05:29 PM
    I am taking my car for a transmission flush Franasia W210 E-Class 17 07-20-2007 07:26 PM
    Transmission Flush NorCal_ML320 W163 M-Class 5 03-07-2006 11:31 PM
