2004 clk320 brake wear sensor question - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-03-2009, 09:42 AM Thread Starter
Date registered: Oct 2009
Vehicle: 2004 CLK 320
Hi all,
Just joined and I have a question regarding the pad replacement in my 2004 clk 320. Do I need to replace the wear sensors when I replace the pads and will that reset the message when I do or is there somthing I need to do in order to reset the message?
twistedmetalman is offline
post #2 of 4 (permalink) Old 10-06-2009, 01:33 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 404 Post(s)
Hi tmm - welcome to the forum.
It seems to be the accepted wisdom to always replace the wear sensor when a pad is replaced, if the wheel has one. Not all wheels have a sensor, and they are not expensive.
My understanding is that the fault message will (eventually) clear itself. If I am wrong about this, someone else will quickly correct me!
keyhole is offline
post #3 of 4 (permalink) Old 10-06-2009, 04:39 PM
Date registered: May 2005
Vehicle: 2004 clk55 amg
yes, in order to reset, you must run around the car 3x's backwards. and as usual, keyhole is correct.
blk05c230k is offline
post #4 of 4 (permalink) Old 10-07-2009, 01:54 AM
unitfreebie's Avatar
Date registered: Oct 2007
Vehicle: 2006 CLK 350
My car (2006) only has sensors on the right side brake, none on the left brakes... Also the sensor wires are very thin and might break when pulling it off the old pads, so it's best to install new ones which you can get from AutohausAZ.
The Brake Light will turn off by itself if the sensor is GOOD.
Also besides running around backwards, bending over for the Dealer will always RESET the brake light! Hahaha
unitfreebie is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
driving w/ brake wear sensor on jesster W203 C-Class 7 11-13-2008 09:40 AM
Brake pad wear sensor? bossman123 W210 E-Class 5 11-30-2007 04:42 PM
Brake Wear Sensor jallbutt W124 E,CE,D,TD Class 3 08-23-2004 04:06 PM
Brake wear sensor M Arrow W163 M-Class 1 02-07-2004 11:06 AM
Brake wear sensor - does it work? sdgrossman1 W124 E,CE,D,TD Class 6 10-13-2003 12:17 PM
