I have a W208 Mercedes Benz CLK320. One of the 13 pins on the Transmission 13-Pin Connector Adapter Plug somehow came off. How would I go about fixing this issue without replacing the entire part? Any help would be greatly appreciated.
Sadly you will have to remove the pan/sump (after draining the ATF) from the transmission then the whole conductor plate has to be removed and replaced.
Search/google these forums and you will find much info on how to do the job. It is the 722.6... transmission.
There must be a way. I googled an image and think it is as attached.
I know a good tip that may work if you have snapped a pin. If you have a syringe needle or simliar you may be able to push this into the broken pin base, then use a little super-glue and it should hold it in place. The needle works well as the point pushes its way into the base and is strong, then you trim off to the correct size.
