99 clk 430 wheel size upgrade - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 05-05-2013, 07:50 AM Thread Starter
Date registered: May 2013
Vehicle: 99 clk 430
went from stock 17 inchers to amg 19s off a cls. bas abs check engine lights. car seems possesed. please help
Foreign is offline
post #2 of 11 (permalink) Old 05-05-2013, 04:58 PM
Date registered: Mar 2013
Vehicle: 2000 CLK430 Coupe & 1997 E320
I reckon you should get the codes checked before you go pinning it on the upgraded wheels.
It sounds like a bad brake light switch which is easily rectifiable (15 min job and only requires a screwdriver and a new brake light switch).
azonic is offline
post #3 of 11 (permalink) Old 05-05-2013, 08:31 PM
hyprr1's Avatar
Vehicle: 2002 CL55 AMG, 1993 190E 2.3L
Quoted: 21 Post(s)
Send a message via Yahoo to hyprr1
Tires too big?
You should have no larger than 275/30/19's in the rear. Anything larger profile
(for example: 275/35/19's would trigger bas abs check engine lights)
Spiros aka "1BADAMG".....
hyprr1 is offline
post #4 of 11 (permalink) Old 05-05-2013, 09:00 PM Thread Starter
Vehicle: 99 clk 430
rear is 265 35 19
front is 235 30 19
Foreign is offline
post #5 of 11 (permalink) Old 05-05-2013, 09:00 PM Thread Starter
Vehicle: 99 clk 430
also none of the lights came on b4 wheel swap
Foreign is offline
post #6 of 11 (permalink) Old 05-06-2013, 08:20 AM
Date registered: Oct 2011
Vehicle: 2002 CLK 430
I did the same swap out (running on exact same tire size currently). I also had error codes curiously thereafter, but I think it was more coincidence. I never had/have heard of what hyprr1 is talking about - mine was rectified through a brake light switch and CPS replacement. For the record, my bas/abs check engine was intermittent and seemingly coming on more frequently (every 4-5 times I would rive the car) - figured it was about time to replace these parts anyways, and haven't seen that light/warning since (year+ ago).
achoren is offline
post #7 of 11 (permalink) Old 05-06-2013, 02:07 PM
hyprr1's Avatar
Quoted: 21 Post(s)
You mean to tell me that you guys both are running 35 profile in the rear?
You cant go bigger than 30 series on 19" wheels in the rear. I know it sounds
nuts but I had the same problem with my C36 AMG. I guess the computer reads
errors because rotation is not consistent.
265/30/19's in the rear & 235/35/19's up front works perfect.
Sorry, but that's my opinion. Just trying to help out.
I bet if you put your stock 17's back on temporarily, you'll see that everything would be fine?
hyprr1 is offline
post #8 of 11 (permalink) Old 05-06-2013, 02:11 PM
Yep, that's what I'm running. I will concede though that it will throw your odometer slightly off over time (per an MB tech who has seen others do the same previously). However, hyprr1 has a good point - throw the 17's back on, and if the problem goes away, there's your issue (and I got lucky!).
achoren is offline
post #9 of 11 (permalink) Old 05-06-2013, 02:12 PM
hyprr1's Avatar
Quoted: 21 Post(s)
here's another post with the same problem!
http://www.benzworld.org/forums/w210...ize-tires.html
hyprr1 is offline
post #10 of 11 (permalink) Old 05-06-2013, 02:39 PM
insame1's Avatar
Date registered: May 2009
Vehicle: 92 190e 2.6 Sportline, 2006 c55
Quoted: 44 Post(s)
rear is 265 35 19
front is 235 30 19
If you are running this setup the rear sidewalls are quit a bit larger than the front. This is more than 2 inches difference in circumference. This can also throw codes.
now if you are running a 30 in the back and a 35 up front then you are only a tenth off.
Never say Die.......
insame1 is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C208/A208 CLK-Class
