Radiator Fan wont turn off!! Help! - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 06-07-2010, 04:21 PM Thread Starter
Date registered: Dec 2009
Vehicle: Clk320 1999 Sport
Send a message via MSN to wf.1990
Angry Radiator Fan wont turn off!! Help!
hello guys! i started my car today after a tranny ATF change, when the Radiator fan in my clk320 turned on and wouldnt turn off.
So whilst still at the shop, he pulled some codes using STAR..it turns out the fan itself was defective, so he changed it with a replacement spare he had..
Still the radiator fan spinned like crazy sounding like jet engine, he also replaced the driver side SAM and a little rectangular metallic box on the driver side front bumper (sorry i dont know wat its called)..and nothin helped!!
no fault codes on the ecu (current or stored)..and the fan would turn of as i turn the engine off..thanks in advance guys..
wf.1990 is offline
post #2 of 18 (permalink) Old 06-08-2010, 04:21 AM Thread Starter
anyone?!:S please ive been at 4 mechanics so far and no one could solve it!!
its extremely annoying to have your car sounding like a jet engine all the time!:@ so please, i know you guys are one of the most experienced people in the world when it comes to mercedes, can anyone just help diagnose this problem? thanks guys..
wf.1990 is offline
post #3 of 18 (permalink) Old 06-08-2010, 07:53 PM
eric242340's Avatar
Quoted: 296 Post(s)
If he has changed the SAM and fan module then there is only the wiring left to check, get a good electrician to look at the wiring.
ERIC.
eric242340 is offline
post #4 of 18 (permalink) Old 06-08-2010, 09:57 PM
~BANNED~
Date registered: Nov 2006
Vehicle: 04 SL500 / 06 ML 500
Quoted: 10 Post(s)
Mercedes Sam Module | Circuit and Wiring Diagram
The problem is likely the electrical thermo fan (temperature) switch. Power is sent to it which turns Fans on/off with the pre set factory temp.
Un plug the temp switch. Use an ohmmeter on it with the key off engine cold. Turn on the key. It should read 1.00 (an open circuit) key off, key on Cold 1.00 or its stuck closed or screwed and time to replace it. The only other possibility is a stuck relay in between the switch (Low amperage)and the fuse box/ Sam module (High amperage)which you can trace by using the multimeter also. Proir Temp switch test should help. This shouldn't be hard to diagnose and fix.
Hary Gahtoe is offline
post #5 of 18 (permalink) Old 06-08-2010, 10:06 PM
eric242340's Avatar
Quoted: 296 Post(s)
^Good info, this should help
ERIC.
post #6 of 18 (permalink) Old 06-09-2010, 06:30 AM Thread Starter
Thanks alot guys!! Well 2 more questions, where exactly is the electrical thermo fan (temperature) switch located? and is the posted link also applicable to a 1999 clk? Thank You again guys
wf.1990 is offline
post #7 of 18 (permalink) Old 06-09-2010, 08:36 AM
~BANNED~
Quoted: 10 Post(s)
I don't have a 6, on a 430 the thermo switch is on the the coolant thermostat housing along with the temp gauge sender unit.
Do a google search W208 Sam module. That one (^)was a 1999-2002 W211
post #8 of 18 (permalink) Old 06-09-2010, 11:41 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 374 Post(s)
You might take a look at the right front fuse & relay box for signs of corrosion from rainwater ingress. (MB claim that it is only splash-proof, not water proof.)
See this thread: http://www.benzworld.org/forums/gene...ying-s430.html
keyhole is online now
post #9 of 18 (permalink) Old 10-15-2012, 02:52 PM
Date registered: Jan 2006
Vehicle: 2000 CLK320, 2004 E320
Hi, did you ever find a solution to your fan problem? My 2000 CLK320 is having the same problem now. Thanks
ooisper is offline
post #10 of 18 (permalink) Old 10-16-2012, 05:29 AM Thread Starter
Well it turned out my airmass flow meter was defective..so maybe you should get it checked..hope that helped
wf.1990 is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C208/A208 CLK-Class
    doors / boot wont lock - key wont turn alberto28 W202 C-Class 0 05-16-2010 01:33 PM
    MERCEDES BENZ CLK 320 Coupe 1999 Need Radiator Fan Shroud+Fan Blade kri7ek General Mercedes-Benz 2 12-07-2009 05:01 PM
    Head gasket leveled, New Radiator, new Thermostat, New fan clutch, both Auxiliary fan Workersvillage W124 E,CE,D,TD Class 11 08-10-2008 11:32 PM
    engine fan or radiator fan fuse and relays ?? DnBtekhnic W203 C-Class 0 04-21-2008 09:40 AM
    heater fan wont turn off....... adrose R170 SLK-Class 2 10-18-2002 09:42 PM
