Went to put on the front hub after repacking/replacing the bearings it seated then I decided to pull it back off to add a little more grease inside the hub between the races. I unseated the hub and now it is stuck, won't go all the way on, won't come off. Should I try yanking it off or gently pounding it back on?
Did you manage to get the hub off without using a puller? I'm surprised if you did.
Anyway, don't bang it on now if it is jammed. Get it off, and see what the problem was before you try again. The WIS shows a puller and an installer are normally required. Did, you check the bearing play? (end float)
I have some details & drawings of the hub and bearing if you are stuck.
Well, didn't have to hit that hard. just paranoid about damaging races,bearings,or spindle. looks like a few blemishes on the race but I could feel nothing. did the brakes on both sides but have to wait for another rear seal and a new grease cap (put a hole in it with a screwdriver, Primitive Pete).
