Hi everyone,
Tonight when I arrived home and pulled the key out of my '00 CLK430, the dash lights started to flicker as did the climate control unit and the beeping noise (as if key was left in ignition) was going off.
I pressed a few buttons on the climate unit and the temp changed as if the car was on, or at least key was turned to accessory setting.
I disconnected the battery for about 20 min, reconnected, started the car, and when I pulled the key out, the same thing happened.
Car runs fine, but this is obviously concerning. Any thoughts before I head to the dealership??
Thanks
Jim
Thanks
Jim
