Cabrio Rear Window Trim - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 08-09-2009, 07:35 PM Thread Starter
Gator430's Avatar
Date registered: Sep 2008
Vehicle: 2003 CLK 430 Cabrio (W208-US Spec) with V60 Puck
Quoted: 2 Post(s)
Has anyone replaced the plastic rear window frame/trim (interior) on their CLK? I'm looking for info on the price of the part and the possibility of DIY. Thanks.
It's GREAT to be a Florida Gator!
Gator430 is offline
post #2 of 9 (permalink) Old 08-10-2009, 03:25 PM
Date registered: Nov 2003
Vehicle: 2000 CLK430 Cab silver/black/ash
Why are you replacing it? Hope you don't have a cable problem?
CLK430Jim is offline
post #3 of 9 (permalink) Old 08-16-2009, 08:42 PM Thread Starter
Gator430's Avatar
Quoted: 2 Post(s)
No, my top works great. The trim is brittle from age and is cracked in a couple of places, and the clips that hold it tight to the headliner are broken, leaving a gap that is visible from the outside.
Gator430 is offline
post #4 of 9 (permalink) Old 08-17-2009, 10:55 AM
Date registered: Jul 2006
Vehicle: 02 CLK55 Conv
I have the same issue. On mine, the clips have broken off the driver-side vertical trim.
Hope to hear something easier than replacing the headliner, since they are sewn together.
I was considering a trim adhesive to bond the trim to the metal windows frame.
Vince
vmaddon is offline
post #5 of 9 (permalink) Old 08-23-2009, 10:23 PM
Date registered: Feb 2003
Vehicle: 2001 CLK430
I am having the same issue, and am prepared to replace the headliner. Is anybody aware of a good source for this part? The Stealership is the only place that I have found it, and they want more than $900....
1987 MBZ 300D 210,000 mi (sold)
1993 MBZ 300D 120,000 mi (sold)
1987 Porsche 928 100,000 mi.
2001 CLK430 Cabrio, 50K mi,
1998 Dodge Ram, 250,000 mi.
cracker928 is offline
post #6 of 9 (permalink) Old 08-31-2009, 09:04 PM
Follow-up.
To save a few $$$ under our current economic times, I decided to try an adhesive.
I ran a small bead of Amazing Goop contact adhesive and sealant along the aluminum windows frame channel where broken trim tabs would insert, and clamped the trim in place for 24 hours.
AG Automotive Product Information 0709
So far, the trim is holding fine with no issues.
I used this product to temporarily repair a small cut in a Sebring convertible top, one of the rivets for the webbing poked through. The temporary repair lasted the life of the top.
Good stuff.
Vince
vmaddon is offline
post #7 of 9 (permalink) Old 07-11-2012, 09:31 PM
Date registered: Nov 2010
Originally Posted by vmaddon View Post
Follow-up.
Good stuff.
Vince
Hi Vince,
I have a similar problem with the headliner trim in my cabriolet, and plan to try your suggestion. May I please enquire what type of clamps you used to hold the trim in place?
Cheers,
Brad
Red Rackham is offline
post #8 of 9 (permalink) Old 02-25-2016, 04:40 AM
Date registered: Jan 2016
Vehicle: 2002 clk320 cabriolet w208
gmwgww
me too,any answers?
gmwgww is offline
post #9 of 9 (permalink) Old 02-28-2016, 10:07 AM
Date registered: Dec 2007
Vehicle: 2001 CLK320 Cabrio
Quoted: 18 Post(s)
The plastic surround is available/replaceable, see thread below for details.
CLK430 Cabriolet rear window 'surround' broken. Replaceable? - MBWorld.org Forums
serndipity is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C208/A208 CLK-Class
    TE rear window trim removal - help needed please. tobyd W124 E,CE,D,TD Class 6 08-06-2008 01:58 PM
    Trim under rear window HELP... BlackSmoke W123 E,CE,D,CD,TD,TE Class 6 03-03-2008 11:19 AM
    Plastic trim broken rear window Dan350 R171 SLK-Class 3 05-18-2005 05:16 PM
    Looking for a rear window trim for '86 MB 420 SEL ??? AAA of NY W126 S,SE,SEC,SEL,SD,SDL Class 0 05-27-2004 10:17 AM
    The ML goes in the shop to replace the rear window trim AndyFracica W163 M-Class 6 12-17-2003 05:11 PM
