Electric seat not working... - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 02-14-2009, 03:35 AM Thread Starter
Sunray's Avatar
Date registered: Dec 2008
HI,
My CLK 320 electric seat on the driver side is not functioning, the forward and backward movement is not working but the back rest and the head rest works perfectly. Can someone advice how i can shift my seat backward to the position i preferred for driving?
Anyone had similar experince or know what is wrong?
Rgds
Ray
Sunray is offline
post #2 of 18 (permalink) Old 02-14-2009, 11:53 AM
bruceinla's Avatar
Vehicle: none
search the archives for seat motor, the motor itself goes bad from what I have read before
Bruce
bruceinla is offline
post #3 of 18 (permalink) Old 02-14-2009, 11:56 AM
arashsheikhpoor15's Avatar
Date registered: Oct 2008
Vehicle: 2002 CLK 55 AMG
Send a message via AIM to arashsheikhpoor15
yes, do a search...or look at some of my posts, i posted the same question, and received lots of good answers.
arashsheikhpoor15 is offline
post #4 of 18 (permalink) Old 02-14-2009, 07:11 PM
Date registered: Feb 2003
Vehicle: 2002 CLK55///04BMWxi///2015 GLK350 4 matic
Quoted: 23 Post(s)
I assume that you have already checked the fuses in the trunk (most common fix/problem). If those are all good, then it's time for a motor replacement...$100 from dealer...remove seat...easy install.
2002 Obsidian Black CLK55
2010 GLK350 4matic sold
2015 GLK 350 4matic designo white
tomtomtomtom is offline
post #5 of 18 (permalink) Old 02-14-2009, 08:07 PM Thread Starter
Sunray's Avatar
Hi Mr Tom,
Do you have a guide on how i can check the fuse? And which fuse is for the seat? Please help..!
Rgds
Sunray is offline
post #6 of 18 (permalink) Old 02-15-2009, 07:26 AM
Quoted: 23 Post(s)
open the trunk..lift off cover...right rear, you will see black box...If I remember correctly, it is the first or second fuse...there is a diagram on inside of cover.
post #7 of 18 (permalink) Old 02-15-2009, 09:28 PM Thread Starter
Sunray's Avatar
HiTomtomtom,
Hmhm.. thats a good piece of advice. But how would i know whether the fuse is ok or not? Sorry, i know i might be asking silly question. But this is my 1st car so i am a bit lost.
Rgds
Sunray is offline
post #8 of 18 (permalink) Old 02-16-2009, 05:12 PM
ludbg's Avatar
Date registered: Feb 2009
Vehicle: 1998 CLK320
Originally Posted by Sunray View Post
HiTomtomtom,
Rgds
take out all the fuses 1 by 1, look at it closely and there is like a little wire inside .... see if its broken. if the wire is fine, the fuse is fine.
hope that helps
ludbg is offline
post #9 of 18 (permalink) Old 02-16-2009, 08:16 PM Thread Starter
Sunray's Avatar
Many thanks.
But I have checked, all my controls are working except for the forward and backward. I presume that only one fuse are for the full seat adjustment, therefore it shouldnt be the fuse problem i think.
Sunray is offline
post #10 of 18 (permalink) Old 02-16-2009, 08:45 PM
ludbg's Avatar
Many thanks.
yep my passenger seat has the same problem. i can still hear a clicking sound when i press the backward and forward button though.... like its stuck...
does anyone if there is a separate motor for up and down and backward and forward?
ludbg is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C208/A208 CLK-Class
    Electric seat belt not working on 94 Coupe fifalex W124 E,CE,D,TD Class 20 10-19-2010 11:08 AM
    Electric Seat not working - CLK 320...!!! Sunray General Mercedes-Benz 6 02-23-2009 03:22 PM
    drivers electric seat stopped working 100% palmer3914 W210 E-Class 15 02-19-2009 04:26 PM
    Electric Seat not working Guest (MBNZ) W210 E-Class 10 12-04-2008 12:40 AM
    Passenger electric seat not working Cori W163 M-Class 1 01-26-2002 12:00 PM
