BAS,ESP,ABS, and P400 code - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 12-16-2007, 09:21 PM Thread Starter
tbsi430's Avatar
Date registered: Oct 2004
Vehicle: 2000 CLK 430 Cab
Quoted: 8 Post(s)
I've recenty been getting the ABS,BAS,ESP malfunction on my cluster display every time I step on the brake after I turn the car on. It stays on until the car is turned off, then on the next start-up it comes back on as soon as I step on the brake. I changed my front brakes today thinking it may have been a bad pad sensor but it didn't change. I then ran a code reader and got the code P400 (EGR Malfunction). I took the EGR off and cleaned out the metal line, it was about 80% clogged. I have to pick up a couple of vacuum lines at the dealer that looked to need changing coming off the EGR. I'm hoping cleaning the line and replacing the vacuum lines will solve it. If not I'm back to square one. Anyone ever had this code (P400) plus ABS, BAS,ESP show up and found a specific issue to cause them all? Any feed back would be appreciated. Thanks.
tbsi430 is offline
post #2 of 6 (permalink) Old 12-20-2007, 08:34 PM
tibimakai's Avatar
Date registered: Feb 2006
Vehicle: 2000 M-B CLK320
with the brake problem I can help you. the culprit it's a switch at the brake pedal, it gets stuck. buy one, at the dealer it's around $14-15.
if you look down there(at pedal) you will notice a switch. remove the connector, switch has a tab which (if I remember well) has to be pushed in and the whole switch will come out by twisting it. same way to replace.
tibimakai is offline
post #3 of 6 (permalink) Old 01-14-2008, 07:18 PM
Date registered: Jan 2008
so I am new here, In fact I joined because of this question. I am looking at purchasing a 2000 clk320- tomorrow actually, and while I had it out for a test drive to the mechanics, this car did this same thing a few times... The malfunction indicator came on with the BAS ESP ABS malfunctions. The mechanic I took it to was just looking for major leaks and issues but he in no way knows MB. I know nothing about cars myself, so I am just checking, does this mean that this problem is not a big deal to fix, and will changing this switch fix all three issues?
Thanks in advance, I really want this car...
it also has a leak from the steering stabilizer and I will be searching this forum for that answer too!!!
couturehottie is offline
post #4 of 6 (permalink) Old 01-15-2008, 03:39 PM
Date registered: Feb 2003
Vehicle: 2002 CLK55///04BMWxi///2015 GLK350 4 matic
Quoted: 23 Post(s)
real easy...
BAS, ESP, ABS problem.....DIY repair - MBWorld.org Forums
2002 Obsidian Black CLK55
2010 GLK350 4matic sold
2015 GLK 350 4matic designo white
tomtomtomtom is offline
post #5 of 6 (permalink) Old 01-21-2008, 12:29 AM
Date registered: Nov 2007
Vehicle: 02 CLK 430, 94 Acura NSX, 97 Honda Accord
Where exactly is this panel to be screwed out that the link refers too? THe pics are great but everything is so close up I cant relate where to look?
150shot is offline
post #6 of 6 (permalink) Old 01-21-2008, 02:27 PM
Mr. Pie's Avatar
Date registered: Nov 2004
Vehicle: CLK320
Send a message via MSN to Mr. Pie
It's all on the driver's side of the car under the steering wheel you'll see the same area which is depicted in the pictures.
2001 W208 Black Opal Metallic
K2a, K3, K4 + COMAND, HID halo projector headlights, flat hood emblem, chrome cluster rings, Bluetooth phone adapter, MB illuminated door sills, AMG steering wheel, AMG pedals, chrome AMG II dual spoke wheels, Nitto NT 555 Extreme Performance, 235/35/19 front, 265/30/19 rear
Mr. Pie is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C208/A208 CLK-Class
    ESP/BAS/ABS KADE W210 E-Class 17 12-01-2013 08:08 AM
    3 Malfunctions - ABS, BAS, ESP juntao C208/A208 CLK-Class 10 12-11-2006 12:03 PM
    Help with BAS/ESP ETS ABS ByByeAmericanPie W163 M-Class 8 09-28-2005 04:40 PM
    BAS ESP ABS Frank C208/A208 CLK-Class 3 08-06-2004 09:41 PM
    ABS, ESP and BAS failure JQ W210 E-Class 5 09-06-2002 02:38 PM
