Need Your Help Guys. 19*8.5 19*9.5 different offset
719 views 3 replies 2 participants last post by  JpdCLK430
I can get a really good deal on a set of wheels, but they are 19*8.5 F & 19*9.5 R. The front has a offset of 37 and the rear is 35. Should I be OK with the offset? Hope so[:D]
#3 ·
The rear may have some clearance issues. I measured mine and I came up with about 28mm. At 35 the difference is 7, I think you'll rub on the front side of the tire on the inboard side. Get 5mm or 6mm spacer and you should be okay. Get the wheels and bolt them up before you mount the tires. That way if they do work you can send 'em back. The front should be fine typically 8.5's run a 35mm offset for a CLK.
