W166 Rear Fog switch from left to right with Vediamo - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-07-2017, 01:29 PM Thread Starter
Date registered: Feb 2009
I'm trying to enable the right foglight on a W166 ML350 2012 that I shipped from the USA to the UK.
WIS shows the wire on pin3 switching from left inner tail light to right inner tail light for RH fog light.
I already switched the wire but light still does not come on, I think its disabled in the SAM
I tried switching around the following values in the CBC file in vediamo, still no fog light.
Fragments Values
PLSM_HW_NSL_li freigegeben
PLSM_HW_NSL_re nicht freigegeben
contents of my SAM coding file are posted at this URL
http://1tlf.co.uk/index.html
would love any pointers to help solve this.
Am happy to pay if someone can do it via teamviewer.
tferrari is offline
post #2 of 3 (permalink) Old 04-08-2017, 02:27 AM Thread Starter
SOLVED
I was so engrossed making sure the wiring was correct, checking voltage etc, I did not think to check the light itself
The right light is actually missing the required LED's (mercedes decided to save a few pennies). Will order a UK replacement
Diesel Benz likes this.
tferrari is offline
post #3 of 3 (permalink) Old 06-19-2017, 03:02 PM
Vehicle: ML500
Quoted: 2 Post(s)
I converted a USA cars whole lighting system to EU about a year ago. You'll find the wiring is missing and Vediamo should be ignored for the rear-fog-light. You'll need to change the rear light (as you've noticed) and cut / run a wire across the boot to the other side.
I suspect you could run a wire from the SAM to the rear foglight and then use vediamo to switch it over ...
R
RichardA is offline
  Mercedes-Benz Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
