A couple of weeks back I bought a used 06 ML350, that has a MCS II command system that lacks the GPS module.
This morning I just won an auction on a complete Command unit WITH the navigation module. Originally I was going to just get a Navigation module to add to my original unit, but ended up with the complete unit for less.
Now I have a few questions:
IF there are codes required for the command radio, where can I find them. I would assume that any type of work done on the car that required battery disconnection would trigger a code request. and without that, I'd be in a lurch.
Thanks in advance for you input.
- If I were to replace the compete unit currently in my car with this one, will I need a security code for the new unit.
- If I were to just add the NAV module from the new unit to the original, would I need some kind of code, or reprogramming the old command to support the NAV module
- Only the quick user guides came with my car, so one of the other manuals are there, nor any stickers with codes.
