97 E420 - Audio System - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 12-01-2011, 11:44 PM Thread Starter
Date registered: Dec 2011
Hi,
I am new here, so I apologize if I am posting something that has already been posted. My question is simple: I just got a 97 Benz E420 and it came with the original audio system. I would like to change it for something else, nothing too fancy, like something I could buy right of Best Buy to plug a USB and play mp3s. However at Best Buy I was told that the only way to have this done is by taking the car to the dealer.
The only Benz dealer in town charges $130 per hour and I have seen and done audio system changes in other cars...so my question is: can I do it on a Benz as well? Where do I buy whatever is that I might need to get this done?
Thanks in advance for your replies
dkodmp5 is offline
post #2 of 2 (permalink) Old 12-02-2011, 02:12 AM
Date registered: Mar 2007
Vehicle: 1997 E420
Quoted: 11 Post(s)
It is not difficult to install an aftermarket head unit from a place like Best Buy into a 1997 E420. I am not an expert but will offer my advice until anyone else chimes in with more knowledge. I was able to get a wiring harness from an install place -- may have been a VW harness as described here but I am not sure...
http://www.benzworld.org/forums/w210...head-unit.html
You can just pop the harness on and connect the wires up as you normally would. You could also cut up your factory wiring harness but it would be a shame to do that when such an inexpensive adapter is available and will keep things clean for the next time you (or someone else) gets in to make changes.
As described in that other post, the main issue (which isn't much of an issue) is that the bose system, which I think was stock for the E420 (do you have bose speakers in your rear deck?) expects 4V input and most car stereos put out 2V low level (from my understanding). The only drawback as far as I can tell is that your volume will be slightly lower than it would be with a 4V output. But my stereo sounds just fine regardless. I suppose it's a safer/better problem to have that most systems put out less voltage, not more, and that it's still an adequate signal.
From what I understand, there are converters available that will change the signal to the 4V input that is optimal or the Bose -- in case you want to get fancy. I've only read a bit about them but it sounds like they may take the SPEAKER level outputs and convert them down to the 4V balanced input that is ideal for the bose system.
Hope this helps! But please check my info with further research, especially if you want to get the converter solution to do an optimized 4V signal for the bose system. The basic install using the VW wiring harness couldn't be much more simple and straightforward, however, and you should be fairly pleased with the results.
"The overall best use of the E420 is not for commuting to work, impressing our mothers, or making sibs jealous. It's for driving as though you were being chased by dogs. Across Montana." (from a review found online)[/SIZE]
ca_tallguy is offline
  Mercedes-Benz Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
1997 E420 Audio Questions Jareb W210 E-Class 4 10-06-2010 05:50 PM
Swap: 1997 E320 Stock Audio System w/ 1999 E320 Wagon Bose Premium System? Matt Whille Audio & Telematics Forum 0 05-14-2009 10:06 AM
Swapping: 1997 E320 Stock Audio System w/ 1999 E320 Wagon Bose Premium System? Matt Whille W210 E-Class 0 05-12-2009 10:02 AM
UK - Digital Audio Broadcast audio system beverage R171 SLK-Class 1 01-20-2005 09:12 AM
any suggestion on what kind of audio system should i use to replace the stock audio? 9JR C208/A208 CLK-Class 3 10-17-2001 06:48 PM
