W211 2005 E55 AMG COMAND PROBLEM - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 07-31-2011, 08:52 AM Thread Starter
Ike Luv's Avatar
Date registered: Jul 2011
Vehicle: 2005 Brilliant Silver E55 AMG
Post W211 2005 E55 AMG COMAND PROBLEM
Guys I searched for this topic & couldnt find anything here, so I apologize if this question has been answered...
05' E55 AMG comand comes on to show AMG Logo but either stays on logo screen or just goes black. Nav doesn't come on, neither does the radio. It has been working fine, it just went black one day to only show the logo screen or just blank all together.
I really would love to avoid the stealership, please help me guys.
Ike Luv is offline
post #2 of 15 (permalink) Old 08-01-2011, 06:04 AM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 256 Post(s)
That is a symptom of an open fiber optic loop. You may have either a loose or unplugged fiber optic connection or else a malfunctioning piece of equipment on the loop that will not allow light to pass.
Check the phone bulletin for your car at Phone Bulletins - it should show you where the connections are located. Start with the easy ones.
If that doesn't work try the procedures at http://www.carstereohelp.com/mercedesFiberOptic.htm and http://www.benzworld.org/forums/audi...d-changer.html
And a final step would be to disconnect the battery for about 5 minutes, then reconnect it. If you do that, you may need Handy Resets for the W220 and possibly other models | Mercedes-Benz Club of America - although written for the S-Class, most of it will work for the E-Class as well.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #3 of 15 (permalink) Old 08-01-2011, 06:50 AM Thread Starter
Ike Luv's Avatar
Thank you very much for your reply......I dont have any tools at all & can change my oil & filter at best, with my low skill set, is this something I can do on my own??
Also, what if I disco fuse #6 then put it back? Would that make it come back?
Also i just noticed that the lights on the NAV disc entry point in the truck are flashing.
Ike Luv is offline
post #4 of 15 (permalink) Old 08-02-2011, 10:05 AM
Skylaw's Avatar
Vehicle: 2013 S550
Quoted: 256 Post(s)
You don't need me to answer the first two, but here goes.
1) You'll only know if you try. Look at the links I gave you and decide for yourself.
2) There are several fuses in your audio system. You could try #6, but I cannot say it will bring it back. However, it won't hurt anything to try.
3) A problem with the CDC may very well be the source of your problem. I have given you a link that addresses troubleshooting, and with what you described, the CDC would be high on my list of early things to try.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #5 of 15 (permalink) Old 08-02-2011, 07:32 PM
Date registered: May 2011
Becker Autosound Website they can help and are local to you bergen county nj
tomm1967 is offline
post #6 of 15 (permalink) Old 08-06-2011, 09:48 AM Thread Starter
Ike Luv's Avatar
Ok, thank you very much friend. I guess I will check the CDC, I'm just really nervous I'll screw something else up in the process.... Guess I will try this weekend...
Ike Luv is offline
post #7 of 15 (permalink) Old 08-06-2011, 09:51 AM Thread Starter
Ike Luv's Avatar
Great, thanks alot. If I'm too scared to crack it open myself, I will def take it to those guys. I checked out the site too. I hope they don't beat me over the head, but I guess thats better than the stealership.
Ike Luv is offline
post #8 of 15 (permalink) Old 08-08-2011, 09:13 AM Thread Starter
Ike Luv's Avatar
So I go to get in the car this morning & the Battery was dead. I assume that the comand stayed on after I got out the previous night. I called Benz roadside assistance (which was here in like 5 minutes) & they jumped the battery. After the car came on, the comand came back, & now it works perfectly. I guess the reset from the battery being dead, reset the comand. I hope it just needed a reset & wont just randomly go out again. Only time will tell I guess. So I hope this helped someone else with a similar issue.
Thanks for your input guys, greatly appreciated
Ike Luv is offline
post #9 of 15 (permalink) Old 09-10-2011, 08:42 AM Thread Starter
Ike Luv's Avatar
Comand went out again...I will try to disco the battery first. I guess this may be an issue now. My keyless go went out of the whole driver side also. After abt 3 or 4 pulls on the door it opens but the rear doesn't open up at all without actually pushing the "unlock" button on the key fob.
Ike Luv is offline
post #10 of 15 (permalink) Old 09-11-2011, 10:06 AM Thread Starter
Ike Luv's Avatar
So I disco'ed the battery & the comand came back. The new problem is that the keyless door open doesn't work & now after the battery was reconnected the pano roof doesn't open, just the window shades on the roof work now...
Is this a dealer trip?
Ike Luv is offline
  Mercedes-Benz Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
    W211 2005 Lower Control Arm Problem? falcon1960 W211 E-Class 11 01-25-2011 05:14 PM
    2005 W211 E320 COMAND Question jbrooks W211 E-Class 4 04-15-2009 04:44 AM
    FS : 2005 US COMAND W211 or W219 no scratches, great shape bighman For Sale/Wanted/Trade/Giveaway 1 10-29-2008 10:36 AM
    2004 W211 Comand vs 2008 W211 Comand? willy_manilly Audio & Telematics Forum 3 09-06-2008 10:10 AM
    Comand DVD - W211 - problem kaziutek50 Audio & Telematics Forum 4 07-13-2008 08:03 AM
