glk 350 help - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 07-21-2010, 06:51 AM Thread Starter
Date registered: Jul 2010
glk 350 help
i am trying to purchase a multimedia device for my glk 350, since i cant find a way to convert the excisting ipod kit to aux port, what is the best unit compatible with this car and that can still be controlled from the center console joystick and sterring wheel controls. HELP
craze012002 is offline
post #2 of 9 (permalink) Old 07-21-2010, 07:15 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
Which head unit do you have currently?
Diesel Benz is offline
post #3 of 9 (permalink) Old 07-21-2010, 07:20 AM Thread Starter
THE STANDARD UNIT IT COMES WITH I GUESS ITS THE 5 INCH SCREEN, THE PACKAGE WITHOUT THE GPS
post #4 of 9 (permalink) Old 07-21-2010, 07:23 AM Thread Starter
ONE MY PROBLEMS IS IT CAME WITH AN IPOD INTERGRADED KIT FROM THE FACTORY AND I CANT FIND AN ADAPTER TO MAKE IT AUX SINCE I HAVE A ZUNE HD, DONT WANNA SPEND MONEY ON ANOTHER KIT, I THINK THE BEST SOLUTON IS GET DIFFERENT HEAD UNIT THAT PROVIDES ALL THE GOODS.
post #5 of 9 (permalink) Old 07-23-2010, 11:04 AM
Quoted: 39 Post(s)
We can hear you.
If you are only after an AUX plug instead of the iPod interface, the simplest approach would be to connect the AUX wire that comes standard for cars without the iPod interface. It connects to the same audio port at the head unit as the iPod interface does. I'm not sure if you car already has the AUX connector with the cable disconnected, not a big deal to retrofit if necessary.
Another option would be to install the UMI or Nav + 4 kit which also includes a standard AUX plug. It is just a bit expensive when it has full navigation capabilities and a set of audio interface options.
I would not consider an after market radio in the case of a GLK.
post #6 of 9 (permalink) Old 07-23-2010, 11:22 AM Thread Starter
THANKS DEISEL, JUST FUSTRATING YOU WOULD THINK MB WOULD COME WITH STANDARD AUX, YEAH MY GLK ONLY CAME WITH THE IPOD INTERFACE AND NO AUX, I AM NEW TO THE WHOLE ADDING THINGS TO THE CAR, DO YOU KNOW WHERE I CAN GET PICS OF THE BACK OF THE RADIO, OR IS THERE WIRE I CAN BUY THAT HAS BOTH PORTS INSTEAD OF ONE, TO HOOK UP FROM THE EXCISTING IPOD PORT BEHIND THE UNIT. THATS COMPATIBLE
post #7 of 9 (permalink) Old 07-23-2010, 06:27 PM
Date registered: Sep 2007
Pretty sure you do still have the AUX port. I will double check in the morning, but it should be on the far side of your glove box. (will update in the AM, when i am 100%)
BenzTime4u is offline
post #8 of 9 (permalink) Old 07-24-2010, 12:49 AM
Quoted: 39 Post(s)
Please try the AUX port too, do not just check if you can see it. I'm afraid the port could be there but the wire has been swapped to the one going to the iPod interface. At best the two would be parallel connected.
post #9 of 9 (permalink) Old 10-13-2015, 08:54 AM
Date registered: Oct 2015
Solution
Hello, did you ever find a solution to your problem? I am having the same issue.
virginiaave01 is offline
  Mercedes-Benz Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
NEW TO YOUR FORUM (GLK 350) tua861 General Mercedes-Benz 6 05-23-2010 06:10 PM
Considering a new 2010 GLK-350 Lend27 General Mercedes-Benz 5 03-06-2010 01:54 PM
GLK 350 US Version vs. EU Mike89 X204 GLK-Class 4 01-31-2010 11:55 PM
GLK 350 Lease btedstrom X204 GLK-Class 5 11-16-2009 11:00 AM
New member in NJ GLK 350 rbednar General Mercedes-Benz 2 08-10-2009 10:59 AM
