» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 11-20-2009, 05:34 AM   #1 (permalink)
Date registered: Nov 2009
210 Multifunction steering wheel display
2000 210 series, no horn, no multifunction display from steering wheel. New multifunction buttons installed, new clock spring. Check all fuses (4) panels. Fuses 40,41 control this function? Installed used instrument cluster just to see any change, none found. You can activate the horn using SDS. Any thoughts or road maps if you've been here before.
germantech1 is offline   Reply With Quote
Malfunctioning Multifunction Steering Wheel liveonpaella New Member Introductions 1 02-21-2009 02:11 AM
Multifunction Steering Wheel On 97 E320 jaamb85 W210 E-Class 1 07-25-2007 06:35 PM
Multifunction Steering Wheel.... PeteK W210 E-Class 4 01-30-2007 12:08 PM
Problem with Multifunction Steering Wheel... PeteK W210 E-Class 0 01-29-2007 05:09 AM
About the multifunction steering wheel... JimG W163 M-Class 0 02-26-2002 12:27 PM
