How to Hook Up OEM Sirius two-wire Antenna directly to OEM Sirius Tuner
I have searched the posts and can't seem to find a solution to my problem. I want to be able to hook up the OEM 2-wire sat antenna directly to the Sat and terrestrial (blue and white) antenna ports on the sat tuner. My 2004 E500 4matic wagon is prewired for sat but I dont want to mount the antenna on the roof, but want to bypass the prewiring and plug the two antenna leads directly into the tuner.
Does anyone know of any adapters or cables with the correct adapters that will let me do this. Alternatively, I would be glad to use an aftermarket antenna if it would solve the problem of directly interfacing to the tuner.
Thanks for any help in advance as I am stumped.
