2004 E320 Pre-Wired for Telephone - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 08-26-2009, 06:01 PM Thread Starter
Date registered: Dec 2008
Vehicle: 2004 E320
I have a 2004 E320 and the Service Tech tells me that my car is pre-wired for telephone. I do have the Tele-Aid system, if that makes a difference.
There is no cradle in the center console, nor is there any visible wire for a cradle hookup. The Service Tech told me that the wire may have to be pulled out from under the console.
Can anybody steer me in the right direction?
Thanks!
ahg100gh is offline
post #2 of 8 (permalink) Old 08-27-2009, 09:34 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Here's the right direction: http://phdwebsite.powerpulse.cc/Phon...Sedan%2004.pdf
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #3 of 8 (permalink) Old 08-27-2009, 09:45 AM
Diesel Benz's Avatar
Quoted: 37 Post(s)
Actually wouldn't the "puck with tail" be the simplest option for this car?
Diesel Benz is offline
post #4 of 8 (permalink) Old 08-27-2009, 10:49 AM
Date registered: Nov 2008
Vehicle: 02 clk 55 cabriolet
You'll also need to make sure you have the "blue label" PSE.
bobbyjo9 is offline
post #5 of 8 (permalink) Old 08-27-2009, 02:02 PM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 256 Post(s)
Yes. It may also be necessary for the dealer to version code the system for full function. The U.S. '04 E-Class has the CP-211, which combines the cell PSE with Tele-Aid. It already has the proper PSE in place; using the puck-with-tail, having a blue label PSE is not a factor.
See http://mbworld.org/forums/e-class-w2...ssions-2.htmlm for some tips on installation.
The only purpose a cradle serves is a place to hold the "puck" portion of the puck with tail. The "tail" connects the puck with the wiring under the floor of the console that the cradle would ordinarily plug into.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #6 of 8 (permalink) Old 08-28-2009, 07:13 PM Thread Starter
Vehicle: 2004 E320
Thank you all for your help.
So, basically, all I would need to do is purchase a "puck with tail," hook it up directly to the cable in the false floor -- and I'm in business?
Thanks!
ahg100gh is offline
post #7 of 8 (permalink) Old 08-29-2009, 05:49 AM
Skylaw's Avatar
Vehicle: 2013 S550
Quoted: 256 Post(s)
Yes.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #8 of 8 (permalink) Old 08-29-2009, 06:16 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
Install infp
Phone Bulletins
Peter Guenther is offline
  Mercedes-Benz Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
    Help required on a Telephone Pre-Wired W209 David H Audio & Telematics Forum 3 05-18-2007 11:40 PM
    Pre-wired telephone fault chrisf65 W203 C-Class 0 04-26-2006 10:51 AM
    pre-wired cd changer connector on E320 1997 dokoroman General Mercedes-Benz 5 02-22-2006 03:05 PM
    hi! I have a pre-wired 2003 E320 but do not own a V60 motorola, any solutions?? E320 benzmomo W211 E-Class 1 09-15-2004 11:28 AM
    2004 M-Class will be pre-wired for Sirius Satellite Radio Tim W163 M-Class 11 04-30-2003 02:07 PM
