» Featured Product
» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 12-12-2008, 05:13 AM   #1 (permalink)
Date registered: May 2008
Vehicle: w204 220 diesel
Question Retrofit a comand in my W204 C class
Im trying to retrofit a original command unit in my W204 C class. The display won’t open, any one got a wiring diagram for the connections to the display?(I’m suspecting that there is a wiring problem since I don’t have the close switch fitted by the went outlet.)
The sound doesn’t work, could it be a problem that my car isn’t fitted with a fiber optic cable?, or should it work even if I don’t have the sound system?
Grateful if someone could answer me on this questions?
oddu is offline   Reply With Quote
Old 12-12-2008, 08:33 AM   #2 (permalink)
Diesel Benz's Avatar
Vehicle: 221.122 & 212.025 & 204.089
I have not done it but I've been thinking about either Comand or Universal Media Interface for the car I've ordered (Comand from factory is ridiculously expensive for us). How much did you pay for the parts by the way?
Did you have the retrofit wiring harness or have you tried to use existing wires?
Are you planning to install the additional fan too? I wonder if it is really needed in hot countries only or everywhere.
Should take some photos and post once you have figured out the whole thing (or even part of it).
Welcome to the forum too.
Diesel Benz is offline   Reply With Quote
Old 12-12-2008, 09:15 AM   #3 (permalink)
I bought it from lituania paid 1200 euros. I planned to use the existing wires, what benefit it it to use a retrofit wiring harness?
Im not planning to install a additional fan, i live in Norway!!!!!!
Old 12-12-2008, 09:57 AM   #4 (permalink)
Sounds like you bought my unit. I was looking at one from Lithuania but did not dare to buy it, the price was a lot lower than that from other sellers that are well known (not in a hurry either, don't have the car yet). I wonder if the wiring kit would have been part of the kit from those others.
You might well need the blower in Norway next summer, but you can put it then if it appears necessary.
I have not compared the wiring but even the Audio 20 is connected to both CAN A and B. I have not seen the connectors either, perhaps they fit but the official retrofit kit would have a wiring loom for some reason.
Old 12-12-2008, 10:40 AM   #5 (permalink)
Is there a official retrofit kit ?
My dealer says it cant be done!!!!! but acording to every seller on EBay its no problem.
The conector to the head unit fits well, the only thing im missing is the fiber optic cable (it not in my car) it comunicates with the dispaly in dashboard so i think the canbus is ok.
I wonder way i cant get any sound, could it be a programming issu?
Old 12-12-2008, 10:48 AM   #6 (permalink)
Do you need the fibre cable? Do you have some devices on the fibre ring?
I don't know about the coding and I've asked a few times but have not seen any replies on Comand or UMI coding issues. I've understood that even the HU is SCN coded on a W204, could be that it does not communicate with the rest of the car before it the car is coded to accept it. I hope you get experts' comments on that (me too then).
Have you read your private mail by the way?
Old 12-12-2008, 11:23 AM   #7 (permalink)
No i dont have anything on the fibre ring, i was just wondering if i had to have a amplifier or something to get the sound working.
I have sendt you a private mail
Old 12-15-2008, 11:57 AM   #8 (permalink)
Today is a great day, i finally managed to retrofit the comand unit.
Works nice
Old 01-02-2009, 05:20 AM   #9 (permalink)
Date registered: Jul 2007
C300 Lux, no Nav, but has SAT
oddu and Diesel Benz; Hello and Happy New Year, oddu, congratulations on the compeltion of the retrofit. I am looking to accomplish the same I am going to purchase a 2008 C300 lux, which already has satellite radio but no Nav. I kinda don't want the UMI as it does not integrate into the existing speaker system. So since I completed an installation of a command system into my current C230, I am ready to tackle the next challenge in the new car. \
What part numbers should I look for to gather the correct parts?
A list of steps and required tools would also be useful to me
Also, you mentioned that the cable to feed info to the instrument panel was not there on your car, how did you resolve this?
I plan to check out the cable harness part numbers for my car and a C300 Sport to determine the difference.
Any help will be most appreciated.
Regards
Nuru
C7nuru is offline   Reply With Quote
Old 01-02-2009, 06:40 AM   #10 (permalink)
Regards
Nuru
In case oddu is not available soon, I'll just say that you seem to be from the US and would then need a different Comand head unit (the display unit must be the same).
I don't think oddu talked about a missing cable to the cluster, on the contrary, the cluster talks with the Comand through an existing CAN-bus, that should be fine in your car too.
I'm quite confused about your UMI interface comment, why would it not use the existing speaker system? That would not make any sense with MP3 players etc.
retrofit bi-xenon headlamps in W204 Savvas W204 C-Class 11 02-15-2010 11:43 AM
ML, GL, R class COMAND APS retrofit RichardA Audio & Telematics Forum 0 09-29-2007 10:37 AM
W210 E-class UHI and COMAND retrofit miroj Audio & Telematics Forum 4 09-03-2006 02:14 PM
Comand 2.0 retrofit in ML mesallem W163 M-Class 1 01-27-2005 01:17 AM
Will the 2000 S class comand cd work on a 2002 C class comand? bzzbenz W203 C-Class 3 04-09-2003 07:28 PM
