» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 12-05-2009, 01:12 PM   #191 (permalink)
Date registered: Jul 2007
Originally Posted by IroNLieR View Post
Hello everyone and congratulations for the thread that is the most comprehensive found on the web! I read it all!
Anyone know tensions are detected on pin power cable for 7" display?
I bought a cable for retrofit from Portugal but appears to be wrong. No connection on pin 8 is a good sign?
Many thanks and best regards
Some have indicated that the original cable will work you just have to position the one side that goes to the rear of the display in a manner that allows it to seat the connector properly. It involved twisting the harness so you can get the correct position to get it into that area and connected. I went ahead and bought the correct cable, but based o what I heard, I tried out my original harness for the 5" display and i was able to get it connected too.
Good Luck
C300 4MATIC
C7nuru is offline   Reply With Quote
Old 12-20-2009, 12:21 PM   #192 (permalink)
Date registered: Jan 2009
Vehicle: 2009 Mercedes C300, IPOD, P2
Can someone make a quick video on how to retrofit. I am extremely interested in retrofitting, but I am scared shi%$*ss!!! Also does anyone know the answer to these two questions:
Can European Comand units work in the US?
Is it essential that one installs the ac blower?
jon145747 is offline   Reply With Quote
Old 12-21-2009, 09:17 AM   #193 (permalink)
Originally Posted by jpimpao01 View Post
Hi, I need help, please....
I bought all retrofit parts (cables, ducts, fan, etc...) I install it all ok (I think) but my radio and display flashing, my display flash black and white and when I turn off ignition it don't turn off. I haven't sound, I haven't image on display....
I saw that I don't have fibre optic in my car....
Can you help me please.... I don't know what I should do more....
Thanks and regards from Portugal (sorry about my english)
Hi, finally I complete retrofit, but I had to buy a new comwand, is it faulty...
Anyone knows how can I reflash it? I think that eproom is damaged...
jpimpao01 is offline   Reply With Quote
Old 12-24-2009, 02:42 PM   #194 (permalink)
1) I have seen one person do it but they had to load US NAV, but then there were issues. So if you are thinking about buying a EURO NAV and using it over here - not a good idea.
2) If you were in Northern Canada, you might be able to get away with it, due to the extremely cold environment, but even the guys who live in Norway are including the Axial blower in their retrofits. Since you are in SoCAL, not a chance put it in. Kinda tough for the commonly skilled folk like myself to install, but for those expertly skilled people like VV, it was not an issue. I got everything in but that and tried for a while (did not want to drop the steering wheel) and the bailed and went to the dealer.
Old 01-24-2010, 11:32 AM   #195 (permalink)
Date registered: Jan 2010
please help
Hi.
I have a question.....i have read the WIS document regarding the retrofit and i didn't understand about the FRONT SAM MODULE ...in the wis document it shows the SAM under the hood near the engine...vic didn't mentioned anything about this SAM module...and i have i wiring diagram... i am talking about N10/1 conector from the APS wiring harness...
deusexisagod is offline   Reply With Quote
Old 01-24-2010, 11:33 AM   #196 (permalink)
Hi.
Old 01-24-2010, 12:14 PM   #197 (permalink)
Diesel Benz's Avatar
Vehicle: 221.122 & 212.025 & 204.089
Originally Posted by deusexisagod View Post
Hi.
He did mention that:
http://www.benzworld.org/forums/audi...ml#post3396620
Is your problem to find out how this connection actually has to be carried out?
Diesel Benz is offline   Reply With Quote
Old 01-25-2010, 02:12 AM   #198 (permalink)
i've got it...i was confused because i read the WIS retrofit document and there was something about renove/install SAM module....and in the pictures providede by vic (write up) i thought the SAM module is near the CAN module...but i figured it up...
Another question...the GPS antenna must pe place under the IC with the sticky part towards the windshield on the black plastic or reversed (the sticky part on the aluminium)?
Old 01-25-2010, 05:48 AM   #199 (permalink)
GPS satellites are difficult to read through the aluminium case. Put the black plastic side upwards.
retrofit bi-xenon headlamps in W204 Savvas W204 C-Class 11 02-15-2010 11:43 AM
ML, GL, R class COMAND APS retrofit RichardA Audio & Telematics Forum 0 09-29-2007 10:37 AM
W210 E-class UHI and COMAND retrofit miroj Audio & Telematics Forum 4 09-03-2006 02:14 PM
Comand 2.0 retrofit in ML mesallem W163 M-Class 1 01-27-2005 01:17 AM
Will the 2000 S class comand cd work on a 2002 C class comand? bzzbenz W203 C-Class 3 04-09-2003 07:28 PM
