HI Moondragon,,
Thank you so much for your comment/input. Is good to know that you are just over the causeway..
In fact, i have already installed a COMAND APS with DVD/MP3. It was a very installation previously, now i m trying to be more adventurous.. i have got the BD0880 in hand (now i found there is BZ9880 which comes with 6DVD Changer built in) and is sitting here starring at me doing nothing. I am doing research and hoping to find some expert here to help me out.
Following are my my uncertainties, can some one please reply by item number accordingly will be of great help.
(1) My old comand is taken out, there is only one connector in the dashboard in front, black square 4 pins, (MOST IN/OUT) P1=T.30, P2T.31, P3=wakeup & P4=reserved.
(2) At the Audio Gateway (N93/1), I found 6 connectors, only able to figure out a 4 nos,
Connector #4 i have center and sub woofer speakers, I can extend
a) Sub 1
b) Sub 2
c) Center
d) FR
e) RR
f) FL
g) RL
I can extend d,e,f & g to the BD0880 but how about a & b?
(this is where i think moondragon suggest HK Logic 7) but i will take this as a 2nd step
Question is now
a) SUB woofer
b) Center speakers will be left unpowered and redundant!
(3) In connector #1, I can try to find the CAN B (High & Low) in the AGW but what to do with
a) electrical wake up
b) TEL Mute
c) MOST IN
d) MOST OUT
Do I have to loop MOST in/out since it is not in use and complete the MOST ring?
(4) What to do with connector #5, power supply and antenna
4 pins connector
(5) What to do with connector#6, MICROPHONE
4 pins connector
(6) What is connector #2 and #3 for? ( in AGW)
Need advice here
(7) PLEASE help me the PIN Layout for the NEW Comand.
I only have found the following
a) what is the 2 white fakra connector -> Radio antenna
b) what is fakra Green connector -> Video IN/TV/Reverse Camera
b) what is fakra Blue connector -> GPS antenna
b) what is fakra Curry(orchard yellow) connector -> GSM antenna
(8) There is one 18PIN connector (square in the middle)
What is this for? Please help!
(9) I need the Fakra Quadlock dual DIN PIN layout
I know there are 3 segments with 4 connectors
a) connector #1 T12 (12 pins) -> i think is reserved and not in use
b) connector #2 T12 (12 pins) -> Can-H, Can-L, Antenna??, Tel MUte
c) connector #3 (16 pins) -> Speakers & Power, 4 speakers only (FL,RL,FR & RR)
d) connector #4 (4 pins) MOST IN and OUT, there is a pair of male & female?
PLEASE HELP
also, Moondragon, or any1 else
Can you please tell me where to buy the connectors? Fakra, Quadlock?
PLEASE x 3
Cheers
Rick
