» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 10-04-2008, 03:55 AM   #1 (permalink)
Date registered: Dec 2007
Vehicle: W124 E320,W163 ML430, Tata Telcoline, Toyota Dyna, Toyota Cressida Wagon 2.4GL, Fiat 350
Volume control Jumping when adjusting
I have finally decided to pull out the radio and check what causes the volume control to jump (sometimes in the wrong direction) when you adjust the volume control knob. This seems worse when you start the car and for the first 10 to 15min things are at the worst, thereafter the volume seems to work just fine. I have noticed that many MLs have this problem, my ML270 was sorted out under warranty by the dealer, and every ML I have test driven has this problem to some degree.
Car: ML430,
Radio: Audio 30
Does anyone know what the problem is? Can I just pull the radio out (with the two radio levers)? What do the two levers look like, I have a few I'm going to try, but is there something special about the ML ones?
Tarydesign is offline   Reply With Quote
Radio Volume Control jumping.. Tarydesign W163 M-Class 8 10-01-2008 08:33 AM
Jumping into the lower control arms today. hotwheelbill W123 E,CE,D,CD,TD,TE Class 1 03-15-2007 10:15 AM
volume control arlmed R171 SLK Class 21 07-14-2005 11:23 PM
Radio volume control Art W210 E-Class 2 03-16-2004 10:52 AM
Adjusting speed sensitve sound volume Guest (MBNZ) Audio & Telematics Forum 2 02-12-2002 06:52 PM
