Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 07-15-2008, 06:11 AM   #1 (permalink)
Date registered: Sep 2007
Vehicle: C 200 CDi estate 2003
IPod on TV pins?
Hello, all.
I want to make ipod connection to comand 2.0, via tv pins, so I can see track names on the cluster. Is this possible? Shouldn't I be able to do something with this pinout?
I think (and I may be wrong!) the phone is using pins 7, 8 and 9 (Can-B shield, LO and HI) of the C2 connector. Maybe I could use pins 16, 17 and 18 (Can-TV shield, LO and HI) of the same connector?
jobela is offline   Reply With Quote
Old 07-16-2008, 02:45 AM   #2 (permalink)
Date registered: Mar 2007
Vehicle: ML350
Originally Posted by jobela View Post
Hello, all.
The phone when used in the phone kit only uses the fiber to send voice and data. the radio itself then sends information to the cluster over CAN-B. You would need to homebrew an adapter to read the ipod serial protocol and convert it to the mercedes CAN protocol to drive the cluster display. Thats *alot* of work.
Your other option would be to use the video out on the ipod and send that to the command LCD instead of the cluster. For that you will still need an adapter made by Dietz which will convert the composite video from the ipod to RGB and also send the necessary commands to enable video in over the TV-CAN lines.
rob13572468 is online now   Reply With Quote
Ipod integration kit / newer Ipod models compatiblity Marconelly Audio & Telematics Forum 9 12-20-2007 09:49 AM
Compatibility of Mercedes iPod Integration Kit with the new iPod classic?? georgi25 Audio & Telematics Forum 1 12-20-2007 09:46 AM
PINS OUT - W164 toodoor Audio & Telematics Forum 0 09-03-2007 02:11 AM
Belkin TuneBase FM for iPod (A true alternative to the MB iPod kit?) Weapon X W203 C-Class 5 06-19-2006 11:20 PM
Does anyone use an IPOD MP3 PLAYER ON THE ML AND HOW CAN YOU CONNECT THE IPOD TO THE CAR STEREO alroumi W163 M-Class 11 01-05-2005 10:29 PM
