» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 07-12-2008, 12:53 PM   #1 (permalink)
Date registered: May 2008
Central locking problem
Hi guys,
have just bought an SLK R170 and retro fitted parking sensors however, now noticed the cental locking isn't working. Not sure if it was working when I bought it to be quite honest and the parking sensors maybe a red herring. I've tried syncronising as per handbook and battery Fobs are ok.
The doors unlock with the door locking switch and keys. Any ideas / help most welcome.
Thanks.
mun802 is offline   Reply With Quote
Old 07-12-2008, 10:41 PM   #2 (permalink)
Vehicle: W211 E320CDI & V221 S320CDI
Did you install the MB OEM Parktronic or some after market sensors? If after market, you should explain which parts of the car (other than the bumpers or at least rear bumper) you worked on.
If it was the OEM set-up, you might have disconnected/broken the remote key antenna when installing the Parktronic display.
Diesel Benz is offline   Reply With Quote
problem with central locking wolfie V-Class 4 02-22-2008 03:49 PM
Central locking problem bielefeld280se W126 S,SE,SEC,SEL,SD,SDL Class 3 06-29-2007 06:42 AM
Central locking problem w124uk W124 E,CE,D,TD Class 6 01-18-2007 01:40 PM
central locking problem? matsmith W203 C-Class 0 12-12-2006 08:15 AM
Central Locking Problem! parker W202 C-Class 1 02-06-2004 12:25 PM
