Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 07-09-2008, 06:38 AM   #1 (permalink)
Date registered: Jul 2008
2002 CL500 start wire?
im doing an install at my work and couldnt find info on this car in our database.
i have done other mercedes but just wanted to check with you guys on the correct wires.
does anyone know the start wire?
(usually a purple wire near a fuse box)
also if you could provide a good under dash constant and ignition that would be helpful!
thanks in advanced
-Josh
thesk8nmidget is offline   Reply With Quote
Old 07-09-2008, 06:59 AM   #2 (permalink)
Vehicle: W211 E320CDI & V221 S320CDI
It would probably help if you would describe a bit more what kind of installation work you are doing. Anyway the wire that puts the starter motor running is violet by colour and you might find it from the right fuse and relay box. But you cannot start the car by making the starter motor run.
The head unit would have constant power, the cigarette lighter would have switched power if you don't need any high currents.
Diesel Benz is offline   Reply With Quote
Old 07-09-2008, 07:09 AM   #3 (permalink)
my bad i instal ignition interlock devices.
they work the same way as a starter kill.
all we need is a ground wire, constant, ignition and then the start wire.
2001 or 2002 CL500 or CL600 carlosamg W215 CL Class 1 07-28-2007 08:04 AM
Valentine One Direct Wire Installation for 2002 CL500 toodeep W215 CL Class 0 01-03-2007 06:45 PM
Fs: 2002 Cl500 Immaculate GCalo For Sale, Trade & Wanted Items 0 06-30-2006 05:52 PM
2002 cl500 black FOR SALE ninorg67 W215 CL Class 0 01-18-2006 06:31 PM
Would 2002 CL500 Wheel fit on 03 CL500 Sport??? JKRD101 W215 CL Class 5 06-13-2005 04:30 PM
