» Sponsor Links
»Garage Storage and Cabinets
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 06-04-2008, 11:32 AM   #1 (permalink)
Date registered: Oct 2003
Vehicle: 2001 E320
The i-Mercedes-D2B iPod adapter from Dice Electronics install
The goal is to eliminate the FM modulator, the cd changer and the 3 in 1 cigarette lighter adapter. 1st thing is that I have the Becker Audio 30 radio. I will be replacing it with the Alpine Audio 10 CD-R which will eliminate the audio cassette on the old radio and replace it with a cd player that reads all different types of cds (cd-r, cd-rw).
1. Remove the radio with radio keys. They slide into slots on the left and right bottom edge. They click in and just slide the radio out. Disconnect the wiring harness which consists of 2 electrical connects (A and B are joined together to form one connector and C is the other connector). Remove the antenna connector and the the fober optic connector. To remove the keys from the radio just push on the metal tabs on the side of the radio and the keys can be pulled out.
2. Remove the cubby above the ashtray by reaching into the empty radio slot and finding a plastic tab on the top back of the cubby and pushing it down. This will release the cubby.
3. Remove the ashtray compartment by 1st removing the ashtray itself. Then pop up the panel around the gearshift and move it to the side. You will see 2 screws holding the ashtray compartment. Just remove them and pull out the compartment. Undo the cigarette lighter connector (try not to break the bulb).
4. I removed the cd changer from the car by lifting up the mat in the trunk and removing the 2 screws that holds the changer in place. Next disconnect the power connector and then the fiber optic cable. I left the connector in the trunk for future use for the next car owner.
5. Next is to wire the box the says "Interface Mercedes Alpine". I chose to use the power from the cigarette lighter by splicing in the fused red to power and the black to ground. I also spliced the brown wire to ground per the install instructions. This is for the AUX function and when I turned on the Sirius radio it had hissing over the speakers until I grounded it. Now there is a blue wire left which is the "Abilitation wire" which is for the fiber optics loop wakeup. On the "C" connector of the radio wiring harness there is a blue and black wire which is for the now removed cd changer. I removed that pin from the connector and replaced it with the blue wire which has a new pin which snaps into the connector. Please remember which hole you removed the pin from or if you can't remove the pin just splice the blue to the blue and black.
6. Now connect the Interface Mercedes Alpine to the box that reads "Dice" with a short cable that has a DIN connector on one end that plugs into the Interface and a 12 pin Molex connector that plugs into the Dice box. I had to open up the Interface box by unscrewing 2 screws in order for the DIN plug to fit and then it locked it in place when I closed the box.
7. Now to connect the provided fiber optic cables 1st attach the RX (receive) cable to the connector just right of the DIN plug on the Interface. Then connect the TX (Transmit) to the other connector. Now plug the other end of the fiber connector into fiber optic port on the radio. Don't worry, it will only go in one way.
8. Now for my install I chose to drill 4 holes into the plastic cubby for the different cables. Hole 1 is for the Ipod cable. Hole 2 is for the AUX cable. Hole 3 is for the power cable for the Sirius Satellite Radio. Hole 4 is for the Sirius Antenna cable.
9. To eliminate the cigarette lighter adapter for the Sirius radio I chose to open up the adapter and remove the circuit board which converts 12 vdc to 5 vdc and wired it to fused power and ground. I just wrapped the circuit board in black electrical tape and pushed the power connector end thru the cubby hole.
10. Connect the Ipod cable to the Dice box by pushing the 8 pin DIN end thru cubby hole 1 and leave the Ipod connector end in the cubby. Connect the AUX cable to the AUX jack on the Dice box and push the other end thru hole 2.
11. On the Dice box are two sets of dip switches. The set on the left is the "car config switch" and the one on the right is the "Ipod config switch". The default settings are all switches set ot "off" which is the up position. I switched the "Ipod config switch" to the "on" positions. This allows you to use the Ipod as you would normally do. In the "off" position the Ipod like an MP3 player will no Ipod functions which is ok for people who do not use ITunes and download their music via Windows Media Player or other methods.
12. Now I placed the two boxes (Interface and Dice) thru the empty radio slot and tie wrapped them in place and out of the way of the radio and cubby. DO NOT BEND THE FIBER OPTIC CABLES, you can curl them only and not alot. Remember that the fiber cable is glass and light will not pass thru bends in the cable. Now reconnected the radio wiring harness and antenna. Reinsert the radio into it's slot.
13. Now I insert the Sirius power cable into cubby hole 3 and the pre-installed Sirius antenna cable in hole 4. I connected all 4 cables to the Ipod and the Sirius radio. I did not reinstall the cubby until I tested everything. I powered up the radio and reentered the code. I then selected the CD function of the radio. I got the Ipod to work playing a song as usual and then by selecting CD 5 track 1 on the radio by pressing the #5 on the radio keypad and then hitting the up arrow on the radio. Music to my ears...Now for the Sirius radio I selected track 2 of CD #5 and again pressed the up arrow.....Again music to my ears.
14. Reinserted the cubby into it's slot. Reinstalled the ashtray compartment and the gearshift panel.
15. As for mounting the items I chose to mount the Sirius radio to the cubby door when it is open by using the provided vent clips that attach to the radio dock. That way I can disconnect it quickly and tuck the cables back into the cubby out of sight. As for the Ipod I chose to just connect it up and pick and play my playlists and then place it into the cubby and close the door.
Special thanxs to OhLord and bs00clk for their assistance with this install.
zx11blade is offline   Reply With Quote
Old 06-04-2008, 01:12 PM   #2 (permalink)
Vehicle: W211 E320CDI & V221 S320CDI
You say the Alpine Audio 10 CD plays all sorts of CD media, my experience is that this head unit hardly plays CD-R disks, not to mention CD-RW disks.
Diesel Benz is offline   Reply With Quote
Old 06-04-2008, 01:32 PM   #3 (permalink)
Vehicle: 2001 E320
I don't have it in hand yet. Still waiting delivery. A friend has one and he plays burned cds without any problems. I will post my results when mine arrives.
Old 11-21-2008, 11:37 PM   #4 (permalink)
ram_rtg's Avatar
Date registered: Feb 2008
Vehicle: JUL 2004 C200 KOMPRESSOR
Hi there, i have the Audio10CD and it plays CD-R very well but not CD-R/W. zx11blade please let mw know how you go with this installation and some pix would be great too! Thanks
ram_rtg is offline   Reply With Quote
Dice D2B instalation manual ZĂ© Bocaina Audio & Telematics Forum 2 05-29-2008 06:43 PM
Install of Argos and Dice ipod gone awry rdrenning Audio & Telematics Forum 6 02-05-2008 07:33 PM
Line to D2B fiber adapter CLK500SE Audio & Telematics Forum 0 01-23-2008 11:59 AM
iPod Integration for Mercedes D2B Fiber Optic Systems Skylaw Audio & Telematics Forum 8 08-03-2007 09:18 AM
iPod Adapter Digital Interface for Mercedes Benz Big"D"inTheMB W210 E-Class 4 07-20-2007 06:12 PM
