» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 02-15-2008, 09:45 PM   #1 (permalink)
Date registered: Feb 2008
Vehicle: 2003 E500 sport
Question help! h/k logic 7 center speaker busted!
hello im new to the site and to a benz. im not shure what im doing with this car. im used to gm's and domestics. i just got the car today its a 03 e500 with the logic 7 harmon kardon system in it and the front center speaker distorts really bad and i think its busted or loose. what do i do about it?
i can take a gm or ford apart in minutes but im not shure on this car. please help guys thanks
shaunls1 is offline   Reply With Quote
Old 02-16-2008, 03:27 AM   #2 (permalink)
Date registered: Mar 2007
Vehicle: ML350
if you have just the inset grille in the top of the dash then it pops up with a pry tool but you might have better luck by pulling out the top vent assembly and prying upward from underneath as the dash on older cars can start to get brittle and may damage when you pry against it.
rob13572468 is offline   Reply With Quote
Old 02-18-2008, 05:02 AM   #3 (permalink)
n5160u's Avatar
Date registered: Apr 2004
Vehicle: 05 C230WK-05 E320CDi
There is a service bulletin regarding distortion from the center speaker. It is caused by wires and other under dash items contacting the speaker. It affects mostly early built W211 like yours.
Potato Chip, custom canuter valve, low-friction muffler bearings, synthetic turn signal fluid, Hi-Definition Progressive Scan Wiper Blades.
Law-makers are supposed to regulate in the interest of the public as opposed to regulating in the interest of the regulated party.
If it says Pratt and Whitney on the outside it better say Martin Baker on the inside.
n5160u is offline   Reply With Quote
Center Fill Speaker disconnect? Nimrodthewombat W140 S-Class 3 11-29-2006 02:24 PM
Adjusting the rear and center speaker levels using Comand? Julien R171 SLK Class 13 01-12-2005 02:56 PM
HK Logic 7 Sound System Speaker info PMK R171 SLK Class 0 11-30-2004 10:00 PM
Center Dash Speaker and Handling Problem mmitchell W211 E-Class 0 02-01-2004 08:41 PM
CENTER SPEAKER FOR W203 COUPE FIXEDupW209 Audio & Telematics Forum 7 12-19-2002 07:13 PM
