Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 01-22-2008, 12:12 AM   #1 (permalink)
Date registered: Jan 2008
Is it possible to increase the size of the COMAND hard drive?
I've heard that a special shock-resistant HD is used because of the constant vibration. Does anybody know the brand of the HD or if it's accessible? I was thinking it would be great if I could double or triple the compacity and load my entire music collection on there. Right now it's limited to 4 GB Would it be possible to take out the existing drive and clone it to a new drive with higher capacity?
BenzBaby09 is offline   Reply With Quote
Old 01-26-2008, 10:53 AM   #2 (permalink)
Anybody??
Old 01-26-2008, 02:03 PM   #3 (permalink)
Vehicle: W211 E320CDI & V221 S320CDI
I guess you have to try to get the first one having some experience on the topic.
My guess is that you would end up having free, inaccessible space. Since the drive would contain navigation data too, cloning may not be straightforward.
Why not use 8.5 GB DL DVD discs and/or a memory card on the PCMCIA slot (didn't W204 have one too). You may still have to swap discs but not often.
Diesel Benz is online now   Reply With Quote
Old 01-27-2008, 01:41 AM   #4 (permalink)
Date registered: Mar 2007
Vehicle: ML350
you are asking a question on a new platform that nobody has much experience with... but not to worry... I was wondering the exact same thing: I assume you are speaking about the W204 C class... the drive is on the bottom of the radio under a protective cover and i happen to have one sitting in my lab. I will snap some pics on monday of the drive.
rob13572468 is offline   Reply With Quote
Old 01-29-2008, 12:03 AM   #5 (permalink)
AWESOME! I am very excited and anxious!
Old 02-16-2008, 02:54 AM   #6 (permalink)
Vehicle: ML350
so I finally remembered to take some pics of the drive today. here they are:
Old 02-16-2008, 02:53 PM   #7 (permalink)
Date registered: Nov 2004
Vehicle: My Benz: 04 S430
Based on the pics. it entirely possible... with two roadblocks possible..
OS or format of the Disc.., and capability of system BIOS.
I would assume that this late in the game no one is using a proprietary drive format, so it should just be either a FAT32 compatible format which means it can be clone on either a mac or PC.. Mac has more options for that...
The exisiting drive is only 8gb. I would try and 80 first if that works try larger is needed. it it does not work, try a 40 then 20..
If neither works,, try another 8 to make sure that the drive can even be cloned.
My04230k is offline   Reply With Quote
Old 02-16-2008, 06:58 PM   #8 (permalink)
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2005 S500 4-Matic
As I read the label in the lower picture, it is a 30GB drive. Look just below the "8455MB." Possibly it is partitioned to serve the varying functions the drive is used for - most likely it is - but it is a 30 GB drive.
30GB is consistent with what I read in MB's introductory materials concerning the system when it was first introduced.
2005 S500 4-Matic
with Gateway 500 iPod integration
Formerly: 2000 S500
with Ice>Link iPod integration
Moto V710 phone with MikBox
Upgraded Voice Control
Skylaw is offline   Reply With Quote
Old 02-16-2008, 11:59 PM   #9 (permalink)
Date registered: Feb 2008
looks like 8455 mega bytes that would be 8 gigs
emcar is offline   Reply With Quote
Old 02-17-2008, 11:23 AM   #10 (permalink)
It is a 30GB drive manufactured specifically for the car market.
See MK3029GAC 2.5" Automotive HDD 30GB
Unless Toshiba design a larger version then no, there is no suitable alternative equivalent. It doesn't mean that a ruggedised 2.5" drive won't work in its place but it is going to be trial and error.
TomTanderson is offline   Reply With Quote
Hard drive upgrade bwallet W204 C-Class 1 01-04-2008 10:55 PM
Shifts Into Drive Hard Sometimes mountainrivera W126 S,SE,SEC,SEL,SD,SDL Class 4 06-03-2007 08:27 AM
PC hard drive questions Espresso Off-Topic 13 03-16-2007 11:59 AM
How hard do you drive your CLK? Atoche W209 New CLK Class 7 06-16-2006 07:18 AM
Increase Microphone volume for COMAND in SLK 350? petes Audio & Telematics Forum 1 10-25-2005 01:26 PM
