Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 01-17-2008, 07:43 AM   #1 (permalink)
Date registered: Nov 2006
Post COMAND APS 50
HI CAN USE W211audio50, MAP CD, INTO W171 audio 50?
evris31 is offline   Reply With Quote
Old 01-17-2008, 08:03 AM   #2 (permalink)
Vehicle: W211 E320CDI & V221 S320CDI
There is no COMAND 50, say it quiet or shout it. Do you mean Audio 50 APS? If both are Audio 50 APS, then the CDs appear compatible.
Diesel Benz is online now   Reply With Quote
Old 01-17-2008, 08:55 AM   #3 (permalink)
yes ,sorry audio 50aps is the same for w211 and w171? and if the cd is copy how to install inw171 need some update?
thanks
Old 01-17-2008, 09:18 AM   #4 (permalink)
The map CD on an Audio 50 would be at the head unit. You don't need to do anything else than take it out from the first car and put it in the the other car.
Or does the other one not load it? Sometimes if some map updates (that existed between the current on the car and the new one) have not been used before putting a new one in, you may need a service CD. I did not check if that could be the case for an Audio 50 APS.
Which map CD version do you have now?
tv tuner for comand/comand aps Roman Aragon Audio & Telematics Forum 12 08-10-2007 01:11 PM
Can I replace my COMAND 2.5 to a COMAND APS? mixmusix Audio & Telematics Forum 0 12-12-2005 10:56 PM
comand APS buchnoun R171 SLK Class 2 11-28-2005 04:16 AM
20 aps vs 50 aps vs comand blackarow R171 SLK Class 1 09-19-2005 03:59 AM
Upgrading Comand 2.5 to Comand APS jjestrada Audio & Telematics Forum 3 07-05-2005 07:36 PM
