» Featured Product
» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 12-10-2007, 05:20 PM   #1 (permalink)
Date registered: Dec 2006
Vehicle: 2000 clk430
COMAND GPS SIGNAL GIVES 00 SAT
I just installed a 2.0 comand in my 2000 clk430, a comand was from w208 also. Radio and CD working fine, I did not have cluster activated. In diagnostics screen I see my speed, direction, gps-00. The problem is GPS will not lock on location, I tried mercedes underdash antenna and aftermarket one. I have a 5V on antenna cable, but still no signal. Anybody had this problem? Software pboblem?
wstasw is offline   Reply With Quote
Old 12-10-2007, 10:11 PM   #2 (permalink)
Diesel Benz's Avatar
Vehicle: 221.122 & 212.025 & 204.089
How long did you wait for the GPS fix? From a cold start it could take quite some time to find satellites. And you should do it preferably under open sky, not in a garage.
Diesel Benz is offline   Reply With Quote
Old 12-11-2007, 12:37 PM   #3 (permalink)
I drive a week with it already, car point wonders all over a map, into rivers, I really getting pissed off by it.
Old 12-11-2007, 10:13 PM   #4 (permalink)
With 0 satellites you cannot expect a lot more after a week's drive. Driving does not make it better for a GPS fix, perhaps this site gives some help if you haven't read it yet:
Mercedes Electronics upgrades, installation and retrofits
Old 12-12-2007, 04:32 AM   #5 (permalink)
Date registered: Aug 2004
Nav.disc must be entered in the comand's nav.drive (original disc, preferably!). Set tire size. Leave car PARKED outside under clear sky for 15 minutes - at least - so the comand unit has some time to find SAT reception.
When comand found its location, drive around the block once or twice in order for it to pinpoint its exact location and its direction.
greetingz,
BigSis
BigSis is offline   Reply With Quote
Old 12-12-2007, 03:09 PM   #6 (permalink)
It takes 2-3 minutes for my portable GPS to lock on location, is Benz gps that bad, is it takes that long everytime for u guys? I do have a disk in it, maybe not original, I got off ebay, but It shows MAP. Any other thoughts?
Old 12-12-2007, 11:59 PM   #7 (permalink)
You mean you need other thoughts, the advice from BigSis did not help? I guess the next advice then is to bring the device for service, likely broken.
Considering the MB GPS fix times, in a normal case it is less than 2 to 3 minutes, significantly less. Now we are talking about a case where the unit has lost time and last position, or even worse, it has a last position which is totally wrong. It isn't odd in this case that the fix would take some time.
My phone would do it with external assistance data and it gets GPS fix in seconds, but that isn't available for the car, not even needed in a normal case.
I'd suggest that you at least confirm you did try the earlier advice, otherwise members who can help may not care to do that.
Old 12-13-2007, 06:38 AM   #8 (permalink)
I notice today it was showing 02 sat for a minute on highway, I think it might be an antenna issue, anybody have CLK430 with blue glass and use merc. underdash antenna? It might be a metalized glass that degrade GPS signal. Ill try to find that spliter and hook to roof antenna.
Old 12-13-2007, 01:21 PM   #9 (permalink)
I doubt the CLK 430 would have IR shielding glass but you could always check from your vehicle data card (from your VIN).
You said in the first post that you had tried two different antenna, you did not use either one "on open sky". Odd if both would have be faulty but of course always possible.
Old 12-13-2007, 02:30 PM   #10 (permalink)
Date registered: Dec 2007
Vehicle: 2008 E350
Some early models could reset gps location by driving in two tight counter clockwise circles then two clockwise circles. Honestly I've never needed to do this and don't think it will help if no sat's are present. Did your last command have a similar problem?
benztech1210 is offline   Reply With Quote
Comand with no GPS signal DanishPete W163 M-Class 2 07-25-2007 08:54 AM
GPS Signal Strength?? mafiaconnected W220 S-Class 6 02-09-2007 08:01 PM
Sat Sticks in Aquiring Signal Mode ssmith314 R171 SLK Class 11 02-20-2006 07:24 PM
GPS SIGNAL 00 ML430 Bulldog W163 M-Class 1 06-01-2004 09:02 AM
gps vs sat radio Ratso W163 M-Class 6 06-05-2003 07:17 AM
