Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 11-02-2007, 12:02 PM   #1 (permalink)
Vehicle: 111 cdi vito compact. and C 270 cdi SLK320
Amps with command
Hi, I have a 2004 Vito with comand and phone fitted.
Can you put a Amp on the comand for better sound?
I think it is 2.0 comand system, but the sound is very poor, probebly speakers need upgrading as well.
Any help please.
Ian UK
zenman 63 is offline   Reply With Quote
Old 11-09-2007, 09:31 AM   #2 (permalink)
Well It seems no one knows!
I have looked into this a bit more and it is the same as fitted to the C class.
It can be fitted with a JL Audio Cleansweep CL441DSP OEM Audio Interface & EQ,
this is so an Amp can be fitted for a clean sound.
You can also fit a JlAudio amp as they have high and low inputs.
Just need to find what will fit the doors now, anyone?
Ian UK
Old 11-09-2007, 11:19 AM   #3 (permalink)
Vehicle: W211 E320CDI & V221 S320CDI
What is a Vito 111 CDI?
If you are after non-OEM speakers, you may have to ask elsewhere, usually the speaker manufacturer gives compatibility info.
The OEM speaker options should be as in the attachment. You may choose according to the best audio option for the car.
Diesel Benz is online now   Reply With Quote
Old 11-09-2007, 12:07 PM   #4 (permalink)
Sorry, A vito 111cdi is a new shape van, 639, just need a size?
Ian UK
Subs and Amps Syracuse315 Audio & Telematics Forum 0 11-27-2005 10:39 AM
amps Mark420 W126 S,SE,SEC,SEL,SD,SDL Class 5 01-04-2005 09:13 AM
Installing Amps Vetteboy3 W126 S,SE,SEC,SEL,SD,SDL Class 1 09-01-2003 12:14 PM
Power to Amps Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 2 01-10-2002 05:25 PM
anyone know much about amps? Guest (MBNZ) W202 C-Class 3 09-29-2001 05:31 AM
