Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 10-31-2007, 05:54 AM   #1 (permalink)
muleears's Avatar
Vehicle: 1998 E300 Turbodiesel, 182K mi. 1987 300D Turbo, 336K mi.
W210 w/Bose intermittant problem
I have a new to me 98 E300 with the Bose sound system with an Alpine CD head unit. I know this is a common problem but I was hoping someone could tell me where to start looking. When I hit a bump I lose a few speakers until the next bump. I know I have a loose connection somewhere but where should I start looking? Back of the head unit? Amps under the rear seat? I lose more than one speaker so I don't think it is at a single speaker, it must be at a junction or common point somewhere. Any help is appreciated.
Cal
muleears is offline   Reply With Quote
Old 11-01-2007, 08:02 AM   #2 (permalink)
RichardM98's Avatar
Date registered: Oct 2007
Vehicle: 98 Brilliant Silver E320 Wagon
Poorly seated cable
If you haven't done so you might try reseating each end of multi-connector cable between the Alpine and the MB harness (radio off). You might also flex each conductor of the cable near the crimps with the radio on to see if any short out. Good luck.
RichardM98 is online now   Reply With Quote
Intermittant Starting Problem Judy M R129 SL Class 11 10-10-2007 08:38 PM
intermittant A/C problem jimwex W208 CLK Class 0 07-11-2007 06:05 AM
Intermittant shut off problem AUSPUFF123 W123 E,CE,D,CD,TD,TE Class 2 07-03-2006 08:23 AM
Intermittant Starting Problem Zyzzyx R129 SL Class 5 04-29-2006 01:22 AM
E300TD W210 intermittant power dodgered W210 E-Class 6 05-25-2005 01:21 AM
