Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 10-28-2007, 02:33 PM   #1 (permalink)
Date registered: Oct 2007
Newbie W220 command problem
Hi,
I just purchased a 2000 W220 S 320CDI and It has the command system.
Strange thing is that the phone and CD changer are not recognised on the command system.
The build-in phone is not switching on (nokia).
The CD changer is getting power (I can load the CD's), but on the command it says CD changer not connected.
Any Idea's?
Any schematics available somewhere?
Thx for any help!
bartk is offline   Reply With Quote
Old 10-28-2007, 06:35 PM   #2 (permalink)
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2005 S500 4-Matic
For the phone, check fuses.
For the CD changer, check the fiber optics connections (orange wires) at the changer.
If either has bad connections or a malfunction, it could cause other problems on the fiber optic loop.
2005 S500 4-Matic
with Gateway 500 iPod integration
Formerly: 2000 S500
with Ice>Link iPod integration
Moto V710 phone with MikBox
Upgraded Voice Control
Skylaw is offline   Reply With Quote
Old 10-29-2007, 12:05 AM   #3 (permalink)
Vehicle: W211 E320CDI & V221 S320CDI
On a MY 2000 E-class, the phone system was D2B connected, if I read right, it is also D2B fibre connected on a MY 2000 W220 also with the fixed phone (but not sure as all early fixed phones were not). Just that Skylaw's comment on the fibre loop could be causing also the phone to fail operation. Looking after the fibre ring sounds a good idea to me.
Diesel Benz is online now   Reply With Quote
Old 10-29-2007, 12:54 AM   #4 (permalink)
Hi both,
Thanks for that already
Sounds reaonable to me. I'm not new to car electronics, however I'm new to the fiberoptics part (sounds pritty fancy )
Any poiters on where this fiber optics is running? You are talking about a loop, is this a ring system (like a token ring network) or just cabes running from the devices to the command system?
Any dissasembly guide for the panels/command in the W220?
For my other car (BM*) the nav system is only a TV panel with buttons in the front, the radio, amps etc are actually in the boot, is this also the case with the merc, or is the command system the complete head unit?
Cheers,
Bart
Old 10-29-2007, 08:32 AM   #5 (permalink)
Skylaw's Avatar
See the phone bulletin (which also shows installation of the CD changer) at Phone Bulletins. While there, you might want to browse Paul's site a bit - there is a wealth of information.
Old 10-29-2007, 03:29 PM   #6 (permalink)
Indeed, this is already a brilliant site!
Thanks already for this info , I'll keep you posted when I found it...
Maybe this question is already answerred somewhere else , but if I would like to upgrade to a DVD nav system... todo or not todo?
Old 10-29-2007, 05:55 PM   #7 (permalink)
Skylaw's Avatar
Only if you go 3rd party. The MB DVD nav systems are for MOST fiber optics, and are incompatible with your D2B bus fiber optics. You do not want to change busses; you'd have to change out everything attached to it (see the diagram in the phone bulletin) as well as all the cables and harnesses - seat removal, tearing up your car - and you're looking at between $10-15K to do it. It is technically possible, but completely impractical.
And going 3rd party can be expensive too. Often gets into replacing audio amps, etc. A little browsing in this forum will get you some information on it, and some are happy with the change - but it's not an option I would choose for myself.
04 W220 Command unlock My04230k Audio & Telematics Forum 7 05-21-2008 12:33 AM
DID YOU HAVE THIS PROBLEM WITH YOUR NEW W220 S500? keide600sel W220 S-Class 4 03-09-2008 10:22 PM
Newbie-unlocking command for 04 E55 david_d23 Audio & Telematics Forum 1 10-07-2007 05:49 AM
WTB: W220 AMG rims, Command CD, AMG TRIM gollard For Sale, Trade & Wanted Items 4 04-16-2007 06:54 PM
W220 Newbie Questions; How can I play DVD's on COMMAND? Man-Du-Ru-Gas General Mercedes-Benz 1 10-17-2004 05:55 PM
