» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 09-25-2009, 05:35 AM   #321 (permalink)
Date registered: Oct 2007
Dahr,
Your tech. is right, there is way too much "black magic" with which adapter works with each phone. I went crazy buying and trying the different adapters with my phone. " See my post above" I am very happy with the viseeo MB2 adapter, it works great. pairs quickly, downloads the phone book completely.
Philip
philip12 is offline   Reply With Quote
Old 09-25-2009, 05:50 AM   #322 (permalink)
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2005 S500 4-Matic, 1978 450SL
Originally Posted by Dahr View Post
I have just purchased a 2003 SL500. The MB technician i had check out the car said it has a V60 cradle in it - and all I need to do is add the "puck". So I go to buy the puck from the parts department.... to be told by the Parts guy - "this only works on a few phones... don't know if it will with yours".
I have a Blackberry Curve (8310 - ATT carrier).
In reading through a lot here... I THINK that maybe this should work the way the tech said.... Am I missing anything here? It sounds too easy... my daily driver car ('97 BMW 740iL) took a bunch of rewiring to pull this off with integration into the auto... and about $1000... (but then again - did that about 4 years ago... things probably easier now)...
My first post - and first day owning car... be gentle
Thanks,
Dahr
Welcome to the forum. You are wise to ask first, before spending a bunch of money.
Compatibility issues and a link for determining compatibility of specific phones and carrier firmware is at permalink #6 on the first page of this string. There is a Blackberry Curve with AT&T firmware that is listed as compatible, but you will have to check your phone to see that it has that firmware. Your phone's instruction booklet should tell you how to do that.
In any case, you will be able pair, and to make and receive calls; the rest of the compatibility issues have to do with phone book downloads. If your phone's firmware is the version listed in the link, you will have full compatibility. If not, the best way to determine how tother firmware will work is to search the forum (not just this string) for individual user experience with a particular phone and Bluetooth puck. Firmware versions newer than the listed version may work fine, and it may not - so if you have the compatible firmware, don't automatically upgrade to the latest version. If your phone's firmware is an older version that the one listed, your carrier can upgrade it easily (Verizon, for example, provides such upgrades over the phone).
What I can say is that since the newer pucks came out well over a year ago, many more phones are compatible. Certain carriers (Sprint in particular) still implement their firmware in a manner that creates problems, and Mercedes is not alone in experiencing them.
2005 S500 4-Matic
with Gateway 500 iPod integration
1978 450SL restoration project
Formerly: 2000 S500
with Ice>Link iPod integration
Moto V710 phone with MikBox
Upgraded Voice Control
Skylaw is offline   Reply With Quote
Old 09-26-2009, 10:31 AM   #323 (permalink)
Date registered: Sep 2009
Vehicle: 2003 SL500
Skylaw & philip... Thank you so much for the replies...
I have a couple follow up questions hopefully you, or someone else can answer.
1) The Viseeo MB2 adapter - i'm reading that it fits 2004 on - "and some 2003".. My 2003 SL500 with the V60 cradle - is it compatible? (It seems like I read that the Viseeo is going to provide better sound quality and a few more features...)
2) Am I able, without a lot of work, able to utilize the SAP Version 3 cradle (and is there any advantage to this?)
3) has anybody utilitzed the "smooth talker" with the blackberry, in conjunction with a bluetooth option, in a R230 (SL 500/550/etc.) - and fit it within the console so it's not cluttered up?
Thanks!
Dahr
Dahr is offline   Reply With Quote
Old 10-03-2009, 11:54 AM   #324 (permalink)
Date registered: Aug 2009
Vehicle: 300 SL 1993 white with black interior
1993 SL
Skylaw,
I am trying to find a solution for my 300 SL from 1993, which has what I believe to be a MB analog phone installed. Obviously not supported by any operator. I want to do something very simple (I think) : find a way to use the preinstalled mike and loudspeakers so I can make hand free calls safely, also using the antenna from the car for better reception. Any idea where I could find an answer to this ? I appreciate your guidance, thanks.
Philippe
Philippe
300 SL 1993
pdavy22 is offline   Reply With Quote
Old 10-03-2009, 03:02 PM   #325 (permalink)
Skylaw's Avatar
Your car is copper wired; the systems with which I am most familiar are fiber optics based.
You may be able to retrofit something like a Kenwood, Pioneer Avic, or Alpine combination nav, DVD, radio, and Bluetooth head unit that would give your car virtually the same capabilities as the newest COMAND units. Some of these units sell for as little as $500, and some for over $1600. There are also separate units that pick up and amplify your cell phone's transmissions and send them out over the car's antenna or an independent external antenna.
If you only want Bluetooth capability, then a 3rd party unit available through many cell carriers would be your best option. They are usually under $200, but they have separate microphones and speakers, and are not particularly integrated with the rest of the audio system.
Old 10-05-2009, 05:16 PM   #326 (permalink)
tx Skylaw, appreciate your answer
Philippe
Old 10-10-2009, 06:23 PM   #327 (permalink)
Date registered: Mar 2007
Vehicle: 1999 s500 134700 miles
Hello all, I have a 2000 s500 sport with the startac phone. wher can i find the esn number? I took the battery out of the phone. to get service they said i need an (11 diget) esn number. pagepluscellular said they can can provide service. THANKS.
jwmsr52 is offline   Reply With Quote
Old 10-10-2009, 08:06 PM   #328 (permalink)
Skylaw's Avatar
I don't recall the menu item, but the esn will be listed in one of the phone information menus.
It is surprising that any U.S. service provider is accepting StarTacs on their network, since they are not E911 capable telephones.
Old 10-11-2009, 07:31 PM   #329 (permalink)
Thanks, i will check thye menu and let u know
Old 11-07-2009, 07:04 AM   #330 (permalink)
puf
Date registered: Apr 2009
1992 500SEL original Phone system
As you, I have a 1992 500SEL with an original analog phone system that I can't use anymore. So, how can I convert or upgrade the existing system to be able to make use of it.
Please help if you can.
Original: key pad & screen combined in dash for wireless
Receiver under armrest front & back
Thanks.
[quote=Icecobra;3636921]
Originally Posted by Icecobra View Post
A quick note... I did a upgrade on my 94 E class and it was a simple part from my MErcedes dealer. It plugged in to the tele aid system under the center console arm rest. It was 4 torx screws and then plug it in. It came right up and I have full blue-tooth compatability, and phone directory download. My phone is a LG Dare touch screen, mt wifes added no problem and it is a Samsung. Both worked perfectly. The down side the dealer tried to convince me it was a 2 hour job and he would need the car for sometime to get this done. I informed him to bring the part out and I would show him how to do it. The good he had a porter go get a torx driver and did it for me at no charge. We made sure it worked before I left. Contact me if you need any help to get this done. It is not a cradle but an adapter to make the command system work with blue tooth. Thanks ( I owned a stereo shop in California for 5 years and I am pretty good with car electronics.)[/QUOTE94 SHOULD READ 04 sorry I am no typist.....
puf is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
How-to Guide For Cell Phone Upgrades, Plug-in And Bluetooth Skylaw Audio & Telematics Forum 0 04-05-2007 02:30 PM
The How-To Guide for Cell Phone Updates and Bluetooth Skylaw Test 6 04-05-2007 02:23 PM
Bluetooth & Integrated Phone Plug ProvingGrounds W140 S-Class 3 01-18-2007 07:35 AM
CLS: Connecting my bluetooth cell phone to MBZ system - how? Teresa Heinrich W219 CLS Class 4 03-27-2006 04:44 PM
Bluetooth Option for built-in V60 cell phone RichRocky Audio & Telematics Forum 2 02-23-2006 06:52 PM
