» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 07-02-2009, 10:22 PM   #301 (permalink)
Date registered: Jan 2008
Vehicle: 2000 Mercedes S500 2002 Yamaha R6
So what is you have 2 phones with you in the car. Can you use both??? (not at the time)
Talk on one and after talk on another one ???
Ramunsa is offline   Reply With Quote
Old 07-02-2009, 10:28 PM   #302 (permalink)
I have exactly the same situation as the guy in this forum: W220 2000 S500....I looked and still cant wrap my thoughts around what I need... - MBWorld.org Forums
My PSE is 9I guess from the forum) CTEL Q6 82 20418, ans next to it is Voice module not sure what the number but I think the same as the guy in the forum. And the phone is the same as in the forum.
Since that post has not been updated for so long does anybody know is connectors would mach if I would get universal or Autosense PSE ??? I am trying to convert to Bluetooth system.
Thanks
Old 07-03-2009, 12:23 PM   #303 (permalink)
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2005 S500 4-Matic, 1978 450SL
No. The newer Bluetooth pucks will allow pairing of up to four phones, but only one at a time. They will search for the last one paired, and if not found, the next-to-last, continuing back to the first one, and starting over. Older pucks would allow only two; and the RAZR Bluetooth/combo cradle allowed 4, but all had to be RAZRS.
2005 S500 4-Matic
with Gateway 500 iPod integration
1978 450SL restoration project
Formerly: 2000 S500
with Ice>Link iPod integration
Moto V710 phone with MikBox
Upgraded Voice Control
Skylaw is offline   Reply With Quote
Old 07-03-2009, 12:34 PM   #304 (permalink)
Skylaw's Avatar
Thanks
Ramunsa, I have to stand by what I wrote in response to the question in the link. Your PSE is for the oldest handsfree system used in the W220, predating the StarTac. I believe its actual part number is Q682 0418.
The question you may have to ask your dealer is whether a Universal PSE will fit your car. If it will, the go the Universal PSE/cradle eliminator/V60 puck route. The dealer will be able to provide the parts at a fairly reasonable cost, as discussed in the writeup, if the Universal PSE can be used.
The OP in your link did not respond, so we do not know how things worked out.
Old 07-04-2009, 05:44 AM   #305 (permalink)
Date registered: Oct 2007
LG Enve 3 and 08' ML350
I am trying to use a LG enve3 and am having trouble, the puck is a #5878, the phone pairs correctly, but the phone book does not load to the command, and the phone has to be re-connected each time I get back into the car, It won't connect by itself. I have used this puck with the razor and Moto Q without any trouble. The system is Verizon. Can anyone help with this one? I have tried to search re: the Enve3 but can't find anything.
Thanks.
Philip
philip12 is offline   Reply With Quote
Old 07-14-2009, 12:19 AM   #306 (permalink)
Date registered: Sep 2007
Vehicle: Mercedes Benz c280
is there any help out there that would upgrade my 95 mb phone system to a blue tooth?
jms54 is offline   Reply With Quote
Old 07-14-2009, 06:58 AM   #307 (permalink)
Skylaw's Avatar
Philip12,
I cannot say for sure, but the firmware on some phones just isn't compatible with MB systems, and will not provide a full feature set - something I wrote about in post (permalink) #6, above.
jms54,
There may be third party Bluetooth solutions available through the phone service provider. Alternatively, many portable nav systems now also provide Bluetooth capability (the Garmin Nuvi 885t, for example). The 885t will provide voice instruction and phone conversations over the car's audio system via FM rebroadcast if you wish; and it offers a traffic avoidance subscription service as well. There are other models of the Nuvi, and other brands besides Garmin, that provide similar features. I recently bought an 885t for my restoration project (a '78 450SL) because 1) nav systems in my car and my wife's car have spoiled me; 2) I don't want to be caught running around in a restoration project that has broken down, and not have a cell phone with me - and the unit is a visible reminder to carry my phone; and 3) the 450SL is noisy enough that its built-in speaker just isn't enough under some conditions.
The cheapest solution for you may be a good BT headset/ear piece, however.
Old 07-25-2009, 06:01 PM   #308 (permalink)
Date registered: Apr 2009
Vehicle: 2005 CL65 AMG - Stock
Does anyone have a link to the instructions? The manuals with the car are no help. I was able to get other bt devices to work except in my 05 CL. I just bought the puk and connected it to the already-installed contact in the armrest. How do you actually PAIR your phone? Where are the step by step instructions?
My1stMBenz is offline   Reply With Quote
Old 07-25-2009, 06:41 PM   #309 (permalink)
Nevermind. I found it. But, the MB pdf won't download for some reason. Luckily I found what I needed.
Old 08-07-2009, 08:20 PM   #310 (permalink)
Icecobra's Avatar
Date registered: Jul 2009
Vehicle: 2004 E-320 Avante garde edition 32 Ford not done yet edition 2001 Tahoe almost used up edition
Originally Posted by Skylaw View Post
The following information is what I have been able to glean from other contributor’s posts; I have not seen this done myself, and would welcome any feedback.
The MY ’03-’04 E Class and ’04 S-Class were equipped with a PSE that combined the Tele-Aid and cell phone support equipment into one unit called the CP-211. All that is necessary in these cars is to “activate” the cell option with STAR diagnosis, and add the proper V60 cradle (kit Q 682 0882 for the S-Class; Q 682 0828 for the ’03 or ’04 E-Class). In addition, the E-Class phone bulletins indicate that a linear compensator and cable are necessary (only for plug-in operation, I would add), and the ’03 E-Class requires an Audio 50 firmware update.
Once the activation is done, a Bluetooth “Puck with Tail” is used for cars with a cradle. This puck differs from the puck used in other ’00-04 cars.
In addition, the new "Cradle replacer" as discussed in the two preceding posts and V60 puck can also be used with the CP-211 platform; this is a particularly easy solution if the car does not already have a V60 cradle.
A caveat for owners of cars other than the E-Class and S-Class discussed in this section: The V60 cradle for the '03-'04 E-Class and '04 S-Class does not use the same connectors as the V-60 cradle for other models, and it should not be substituted unless you can get the adapters that are necessary. In addition, I have no idea what the outcome of adding a CP-211 PSE to an earlier car that still had its original Tele-Aid equipment in place. Although it may be possible to take the OE Tele-Aid out of the fiber optic loop, I don’t know if the CP-211 can be made to work in installations for which it was not designed.
A quick note... I did a upgrade on my 94 E class and it was a simple part from my MErcedes dealer. It plugged in to the tele aid system under the center console arm rest. It was 4 torx screws and then plug it in. It came right up and I have full blue-tooth compatability, and phone directory download. My phone is a LG Dare touch screen, mt wifes added no problem and it is a Samsung. Both worked perfectly. The down side the dealer tried to convince me it was a 2 hour job and he would need the car for sometime to get this done. I informed him to bring the part out and I would show him how to do it. The good he had a porter go get a torx driver and did it for me at no charge. We made sure it worked before I left. Contact me if you need any help to get this done. It is not a cradle but an adapter to make the command system work with blue tooth. Thanks ( I owned a stereo shop in California for 5 years and I am pretty good with car electronics.)
Icecobra is offline   Reply With Quote
How-to Guide For Cell Phone Upgrades, Plug-in And Bluetooth Skylaw Audio & Telematics Forum 0 04-05-2007 02:30 PM
The How-To Guide for Cell Phone Updates and Bluetooth Skylaw Test 6 04-05-2007 02:23 PM
Bluetooth & Integrated Phone Plug ProvingGrounds W140 S-Class 3 01-18-2007 07:35 AM
CLS: Connecting my bluetooth cell phone to MBZ system - how? Teresa Heinrich W219 CLS Class 4 03-27-2006 04:44 PM
Bluetooth Option for built-in V60 cell phone RichRocky Audio & Telematics Forum 2 02-23-2006 06:52 PM
