» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 01-17-2007, 09:10 PM   #1 (permalink)
Date registered: Jan 2007
Vehicle: 2000 S500
Nav Disk Interchangeability
I have a 2000 S500 and recently purchased a used complete set of the MB nav disks for 2005 (thru eBay). These, I find, do not work in my nav system. Does anyone have data on disk interchangeability? I'd like to sell these to someone who can actually use them, and buy the right upgrade.
Thanks!
Life is full of Benz in the road
BenzInTheRoad is offline   Reply With Quote
Old 01-18-2007, 03:41 PM   #2 (permalink)
Date registered: Nov 2006
Vehicle: 2001 S430
You may want to do a search for the specifics but I believe there were different versions, A, B, C, etc and I believe, this is the part you may want to do the search on, that there was a change of head units some time in the 2000MY and the earlier disks dont' work on the later or vise versa. Do a search and you'll probably find more info than you want.
poormario is offline   Reply With Quote
Old 01-18-2007, 05:52 PM   #3 (permalink)
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2005 S500 4-Matic
Thanks!
The following link tells you why, and has another link to help you determine what kind of nav system you have. The best source of CDs for your system is the dealer. There is a link to an alternate source in the following link as well: http://forums.mbworld.org/forums/sho...ghlight=Skylaw
If your e-bay discs won't work there are two likely possibilities: They were for the other system, or they were pirated.
Good luck. The change from C nav to D nav in the midst of the production year (I believe it was November of 99) causes problems for a lot of folks.
2005 S500 4-Matic
with Gateway 500 iPod integration
Formerly: 2000 S500
with Ice>Link iPod integration
Moto V710 phone with MikBox
Upgraded Voice Control
Skylaw is offline   Reply With Quote
Old 01-19-2007, 10:57 AM   #4 (permalink)
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
Since you say your CDs are 2005 (hopefully 11/05 not the 01/05) they should be for NAV D. If you have NAV D and they still don't work, check to make sure they are made by NAVTEQ. Skylaw's link should help you a lot. Please report back.
Don't believe everything you think
http://www.kcmbca.org/
Jayhawk is online now   Reply With Quote
Old 01-19-2007, 11:35 AM   #5 (permalink)
Vehicle: 2000 S500
Disk release correction
I misspoke... my disks are release 01/04. I was working from memory and had a senior moment. Tonight I'll check to see which nav system I have, per Skylaw
:-) BenzInTheRoad
Old 01-19-2007, 12:33 PM   #6 (permalink)
Jayhawk's Avatar
:-) BenzInTheRoad
Those are three years old and the map data were probably collected four years ago, but if they are NAVTEQ and you have NAV D they should work in your COMAND system.
What's the latest nav disk available? aquascape R171 SLK Class 2 11-20-2006 09:02 AM
2005 MCS DVD NAV disk update in a 2003 ML350 I E with DVD NAV... S4toML W163 M-Class 4 12-25-2005 10:02 AM
New Nav Disk endodoc W164 M-Class 38 09-29-2005 09:00 PM
New Nav Disk? endodoc Audio & Telematics Forum 1 09-09-2005 09:34 AM
Possible Wrong Nav Disk For 2006 ML endodoc Audio & Telematics Forum 5 08-02-2005 09:28 PM
