Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 11-09-2006, 05:00 PM   #11 (permalink)
Date registered: Nov 2006
Problem with unlock comand aps 50
Hi
I own a C 220 CDI 04/2004 with APS 50 and I can't unlock Comand..
I can see Engineering ... but I can not acess Secret..
Can someone help me?
Thanks
OriStifler is offline   Reply With Quote
Old 11-10-2006, 10:42 AM   #12 (permalink)
Date registered: Oct 2006
Vehicle: 2007 SL 550/Toyota Landcruiser/56 Ford Thunderbird/BMW LT1100
I concur with the above. I have a 2007 SL and the mute-phone-serv procedure doesn't bring up any menu. I also would appreciate any current model year codes...thank you
Indian Wells is offline   Reply With Quote
Old 12-12-2006, 06:36 AM   #13 (permalink)
Date registered: Dec 2006
me too... doesn't work, and i have the E 320 CDi from 10/2006
nokia3330br is offline   Reply With Quote
Old 12-13-2006, 04:25 AM   #14 (permalink)
dwf
hi i got my GL 320 the codes do not unlock the command aps. How can you see what version of command aps we have?
Anyone has installed a us receiver hitch on a GL ?
Have a good day
dwf is offline   Reply With Quote
Old 12-15-2006, 12:06 AM   #15 (permalink)
tariq53's Avatar
Vehicle: MB S350, 2006
I have S350/2006.. and can't unlock the command!... any help?
tariq53 is offline   Reply With Quote
Old 12-18-2006, 07:50 AM   #16 (permalink)
watson's Avatar
Vehicle: CLS 320 CDI
Hi guys. At last I got the solution !!! . It was so simple. It's a little instrument to connect through the usual slot to the optical ring. In about 1 minute the job is completed and it can be disconnected. Easy. They say it's permanent. It works just fine. I think that it can be found everywhere (U.S.A., U.K., Germany....)
I don't like to spread the information everywere. I have the idea that if the key sequence had not been spreaded , may be M-Benz wouldn't change the engineering mode entry point so soon. So all the friends of the forum needing this information can write to flavio.morosi@tiscali.it. I'll reply as soon as possible.
watson is offline   Reply With Quote
Old 12-19-2006, 10:09 PM   #17 (permalink)
teixed's Avatar
Date registered: Jun 2006
Thanks vikingprince!
teixed is offline   Reply With Quote
Old 12-28-2006, 11:38 AM   #18 (permalink)
solution to comand "problem"
I have the new E-class 2006. And none of the unlocking codes work for getting into the engineering mode but i took the car over to my mercedes dealer and asked if he could "open" the comand system so that the codes would work. it took about ten minutes he hooked the computer up and bingo now it works, they take a small fee for unlocking the command about 1-20 pound here in Denmark......
makal is offline   Reply With Quote
Old 12-29-2006, 09:49 AM   #19 (permalink)
Vehicle: 2002 CLK320 W209
What does the "mp3 play" give you - does it allow the COMAND to play a CD of MP3 files? Does it show the tag info from the MP3 file (artist, title etc)?
colh is offline   Reply With Quote
Old 03-24-2007, 10:09 PM   #20 (permalink)
Date registered: Mar 2007
S350 Unlock Codes
Hi all,
I too would like to let my passengers watch TV whilst I drive. Has anyone had any luck with a "work-around" to disable the lock whilst driving. Vikingprince's solution did not work for my car.
The_Don is offline   Reply With Quote
How Do I unlock my telephone? ryme4reson W140 S-Class 10 09-12-2008 06:12 AM
Unlock TV on Command ML400 MY2002 bedetti W163 M-Class 15 06-22-2008 04:40 AM
Any more unlcking codes for command? DVS SLK R171 SLK Class 12 06-26-2007 10:18 AM
Squeak during unlock Schnell SLK32 R170 SLK Class 3 09-05-2006 02:23 PM
Command unit unlock code 93600 W211 E55 AMG, E63 AMG 0 07-06-2006 06:01 AM
