» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 03-10-2006, 05:17 AM   #1 (permalink)
Date registered: Mar 2006
Vehicle: MB E270 Avant. W211
iPod Integration - E270 W211 (2003) - Aux in glovebox
Hi,
I own a 2003 E279 W211 to European Specification.
It's got the Navi Commnad APS, a CD Changer and an AUX jack in the globebox.
What is the best solution to integrate my brand new iPod 30GB?
Many thanks
Jesus Oregui
JMOA is offline   Reply With Quote
Old 03-12-2006, 05:27 AM   #2 (permalink)
RE: iPod Integration - E270 W211 (2003) - Aux in glovebox
JMOA - 3/10/2006 8:17 AM
Hi,
Many thanks
Jesus Oregui
From what I can gather, there are 2 main options. To be able to listen to the music on the iPod, you can spend £1 and buy a 3.5mm stereo jack to 3.5mm stereo jack wire.
Alternatively, to be able to control the iPod through Comand and scroll with the steering wheel buttons etc, add another £249 and get an integration kit fitted.
I know which option I'm going for..!
jdrrco is offline   Reply With Quote
Old 03-19-2006, 03:53 PM   #3 (permalink)
Thank you very much for your response. It´s taken me few days to get the cable with the 3.5mm jack at both ends. I have tried but it doesn´t work.
My questions now are:
Is the AUX jack in the glovebox truely wired to the Commnad Unit?
Is the AUX jack a 3.5mm standard stereo jack or perhaps something different or special from Mercedes?
Is there anyway I can test the AUX by plugging another device?
Cheers
Old 03-19-2006, 06:55 PM   #4 (permalink)
Date registered: Nov 2004
Vehicle: My Benz: 04 S430
the jack is a standard 3.5mm miniplug ( stereo).
You can connect any device to it, it only plugs into the back of your command and sends the audio signal from whichever device you have plugged in to it.
YOu have to select audio fron your command. It should work of it's plugged in to the back of the command. That's all there is. unless your device has the volume down....Just to double check...., oherwise, it will work.
My04230k is offline   Reply With Quote
