Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 01-12-2006, 03:50 PM   #1 (permalink)
Date registered: Jun 2005
Crackling rear speakers
Does anyone have the wiring diagrams and spec's to overhaul a series amp in a 1992 300SE. Part number is 140 - 820 - 00- 0089 (Bose). can be contacted via email @ ljanderson53@hotmail.com. Thanks
anderson is offline   Reply With Quote
Old 01-13-2006, 06:00 AM   #2 (permalink)
Date registered: Dec 2002
Vehicle: 92 500SEL -01 E320T
RE: Crackling rear speakers
The electrolytics in both the amp and tuner dry out and short (there are a lot, you should replace them all), sometimes they take the foil with it. There are seven amps that feed eleven speakers. If you are trainded to work on printed circuits and have tools and experience, you can probably fix it otherwise there are places that rebuild them and give you a warrantee
http://www.mercedesradiorepair.com/
http://www.carstereohelp.com/strmercedes.htm
You can also go to the becker site for a list of authorized repair dealers including them.
http://www.beckerautosound.com/
Peter Guenther is offline   Reply With Quote
