» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 11-03-2005, 06:25 AM   #1 (permalink)
Date registered: Nov 2005
New Blue tooth phone in S430 info needed
Hi, i'm a new owner (well its my wifes car) of a 2003 S430. She wants a phone installed in the car with the ability to talk hands/headset free and use the controls on the steering wheel and Nav. She also wants to be able to talk using a blue tooth head set if other people are in the car.
I'm not sure where to start with this or what I need. She is changing jobs and will be changing cell phone providers. So she figures she will just pic a phone/provider that will be compatable with the cars system.
Where should I start with this? Mikbox
Groundpounder03 is offline   Reply With Quote
Old 11-03-2005, 07:55 AM   #2 (permalink)
RE: New Blue tooth phone in S430 info needed
FYI for anyone who can help, I just check the original sticker for the car says it it is pr wired for phone and voice control.
Old 11-03-2005, 08:29 AM   #3 (permalink)
BenzWorld R171 Host
ianx, manchester's Avatar
Vehicle: SLK350
Groundpounder03 - 11/3/2005 2:55 PM
then the official MB kit which will come out may be just what you need.
have a look here...
http://www.benzworld.org/forums/forums/thread-view.asp?tid=1232213&posts=24&fid=27
ianx, manchester is offline   Reply With Quote
Old 11-04-2005, 10:16 AM   #4 (permalink)
firstmb's Avatar
Date registered: Jan 2005
Vehicle: 2006 ML350
ianx, manchester - 11/3/2005 9:29 AM
have a look here...
ianx, As you being a moderator, I am suggesting that the bluetooth thread on R171 should be made as a sticky in Audio & Telematics forum. Thread created by you in R171 is the only thread with complete information and pics. There are hundred of questions posted related to Bluetooth again and again in all fourms. IMHO
Thanks, D.
________________________________________________
2006 ML 350 - Black, Appearance Package, Navigation System, Entertainment Package, Sunroof Package, Heated Seats, IPod Integration
firstmb is offline   Reply With Quote
Old 11-04-2005, 11:37 AM   #5 (permalink)
BenzWorld R171 Host
Vehicle: SLK350
firstmb - 11/4/2005 5:16 PM
I can certainly move it, but i can't sticky it. I don't have that privilege for this forum.
If the forum host drops me line i'll do the necessary!
Old 11-05-2005, 07:28 AM   #6 (permalink)
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2005 S500 4-Matic, 1978 450SL
ianx has provided a valid suggestion; however, if your car is simply prewired and has never had a phone, you will have to equip it with a PSE, a Y-cable, a cradle, and possibly a dual-band linear compensator (for the car's antenna). You can check the equipment that would be installed if the car had been ordered with a phone in the phone bulletins on Paul' site at http://home.earthlink.net/~phdwebsite/phone_bulletins.htm
With that equipment, you could follow the path suggested by ianx, or use a MikBox; you can see my installation of a MikBox in a '00 S500 at http://forums.mbnz.org/publications/pub.asp?id=317 Your car's electronics mounting will be slightly different from mine, but the phone bulletin should get you through the differences.
With the MikBox, you should order the phone cradle from MIK; he provides it with the RJ-48 and antenna connector you need.
The MikBox (right now) requires Motorola phones that can be plugged into a cradle. However, you should still be able to use the phone with a Bluetooth headset if you buy one that is BT enabled, and has (at minimum) the Headset protocol enabled. Even the original Verizon V710 (and the 815) have this. So, the MikBox remains an option for you.
2005 S500 4-Matic
with Gateway 500 iPod integration
1978 450SL restoration project
Formerly: 2000 S500
with Ice>Link iPod integration
Moto V710 phone with MikBox
Upgraded Voice Control
Skylaw is offline   Reply With Quote
Old 11-07-2005, 08:25 AM   #7 (permalink)
firstmb's Avatar
Vehicle: 2006 ML350
Getting error message while accessing site
Old 11-07-2005, 09:50 AM   #8 (permalink)
Thanks for the info Skylaw. That clears it up a bit for me. I guess I need to determine what exactly I have in the car first...then go from there. I'm taking it in on Thur for service. I'll see if I can get them to tell me what I have already pre installed.
Old 11-07-2005, 09:51 AM   #9 (permalink)
Oh yeah, I too am getting the error message for that link. Thanks
Old 11-07-2005, 03:59 PM   #10 (permalink)
Skylaw's Avatar
firstmb - I just clicked the link on your post, and got the site. There may have been a server or other network problem. Try again - if it won't work, try copying the link and pasting it into the browser window. Or, go to my writeup (the other link) - there's a link to it there.
