» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 07-05-2005, 04:37 PM   #1 (permalink)
Date registered: Jul 2005
No Sound on radio, No Sound on TV, No CDC changer and NO PHONE!
Intermittent problem on a 2002 S320. Service center cant fix the problem even after several trials. What should i do to it.
st_tropez72 is offline   Reply With Quote
Old 07-07-2005, 03:20 PM   #2 (permalink)
Date registered: Mar 2004
Vehicle: W203 modified
Send a message via MSN to miroj Send a message via Skype™ to miroj
RE: No Sound on radio, No Sound on TV, No CDC changer and NO PHONE!
st_tropez72 - 7/6/2005 8:37 AM
5 possible causes spring to mind
1/ The fibre optic ring is broken
2/ The wakeup lines are damaged
3/ One device is unpluged from cables
4/ Blown fuse on one of those items
5/ One or more devices have become faulty.
Modz ... enjoy the difference. www.benzmodz.com
miroj is offline   Reply With Quote
Old 07-07-2005, 07:37 PM   #3 (permalink)
mdvijay's Avatar
Date registered: Apr 2005
Vehicle: SL55,G500,C320,560SL,300SDL,F430SPIDER
had the same problem today on my 2003 sl 55 amg spoke to service manager at mb dealership .adviced me that it is not common but they have seen that ,just turn the key off and remove the key and wait 15 seconds and restart .i did the same it worked .his advice if this is happeming again the only solution is to replace the command unit
good luck will keep the fingers crossed hope it works for you
mdvijay is offline   Reply With Quote
Old 09-01-2008, 08:40 PM   #4 (permalink)
Date registered: Mar 2008
how do you replace the optic ring?
mbcspr is offline   Reply With Quote
Old 09-01-2008, 10:59 PM   #5 (permalink)
Diesel Benz's Avatar
Vehicle: 221.122 & 212.025 & 204.089
Dig out all the fibre cables and put new ones in. You have to disassemble most of the car usually in order to do this.
But how did you conclude from this old thread that you would have to replace the whole fibre ring?
Diesel Benz is online now   Reply With Quote
