» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 07-18-2004, 12:58 PM   #1 (permalink)
Date registered: Oct 2003
COMAND head unit not reading discs! Help!
I am very bummed. My COMAND head unit just suddenly stopped reading discs! I have tried regular audio disc (not burned) and real MBZ NAVI discs (that used to work just fine)
When it is a NAVI disc I get and error that says:
CD-Reading Error: Please use another Navigation CD
When using an audio disc:
CD Drive
Reading Error
The rest of the functions on the head unit seem to work just fine and the Changer (thank goodness) continues to function just fine.
Any ideas? I hope I am not screwed. Is there a way to clean the drive?
Thanks,
Jim
wujian is offline   Reply With Quote
Old 07-18-2004, 05:00 PM   #2 (permalink)
Vehicle: 2002 C230k
RE: COMAND head unit not reading discs! Help!
Sometimes the cd-rom drive goes bad. It can be replaced. I don't know what that would cost or where it can be done. Possibly a Blaupunkt dealer could do it.
2002 C230k, 6 speed, jaspisblau, charcoal leather, C4, C5, C7, Euro COMAND
Lynn is offline   Reply With Quote
Old 07-19-2004, 08:43 PM   #3 (permalink)
paulhdick's Avatar
Vehicle: 2001 ML-320, C-320
Have you tired doing a system reset??
Paul[?]
01 ML-320 -- M1 Luxury Package, M2 Convenience Package, Bose® Premium Audio w/integrated 6-disc CD-changer and Bose sail-panel tweeter add-on, OEM 3rd Row Seat Package, OEM DVD navigation, OEM MB V60 integrated cell phone upgraded to a non-Mercedes Motorola V551 using the Mix-Box 100 Interface, Voice Control, OEM vehicle entertainment system with OEM VCP, OEM DVD player, and OEM wireless headphones, OEM Style 1 chrome brushguard with skidplate, OEM Style 1 chrome sidesteps, OEM fender flares, OEM rear mudflaps, OEM PIAA (959) fog lamps & matching H3 PIAA Crystal-Ion integrated fog beams, OEM trailer hitch with (modified) Bully stainless steel hitch step, Schatz oval exhaust tip, Schatz chrome a/c rings, OEM AMG chrome cluster rings, and some esoteric stuff you will probably never notice ... but I know it's there.
paulhdick is offline   Reply With Quote
Old 07-19-2004, 09:51 PM   #4 (permalink)
um... I don't think so.
How can I do a system reset? I just looked throughg my manual and I and missing it.
any guidance?
thanks in advance...
jim
Old 07-19-2004, 09:51 PM   #5 (permalink)
any guidance?
jim
Old 07-20-2004, 02:01 AM   #6 (permalink)
scorchie's Avatar
Vehicle: CLK55/G500/E55/ML55/etc.
If it SUDDENLY stopped (as you wrote), it is probably not a dirty lens on the laser... when dirty, the reading performance tends to deteriorate over time, with sporadic errors occuring and becoming worse over time. Since yours was working fine and then completely stopped working, it is more likely due to some hardware failure.
A replacement CD-ROM drive may be in order; if the unit does not come back after resting for a while, then it will likely need repair.
If some extreme condition occurred which has caused this (very high temperature, or some excessively dirty environment which may have deposited a lot of residue on the lens), it is possible that waiting for the unit to cool down, or a commercial disc cleaner, will help.
-s-
1987 190E / 1987 300E x2/ 2001 CLK55 / 2001 ML55 / 2002 G500 / 2003 E55 / 2006 R350 / 2006 G450 / 2007 sumtin sumtin
scorchie is offline   Reply With Quote
Old 07-20-2004, 07:13 AM   #7 (permalink)
paulhdick's Avatar
It's not in the manual .......
You can do a “System Reset� from the “Diagnosis� screen in “Service� mode. To get to the Diagnosis screen go to the SVC (or SYS on Euro versions) screen and select AUX. Press the “MUT� (mute), “1�, and “3� buttons all at the same time for about 5 seconds … this will take you to a Service screen. Select “Diagnosis�, and then select “System Reset�. I will keep my fingers crossed for you but the CD players are known for problems from time to time.
Good Luck …
Old 07-20-2004, 02:11 PM   #8 (permalink)
aw, maaaaan!
Thanks for the instructions on the systems reset. I completed that and 7! Crapped out... the CD player has the same error messages. I will try a "can o air" and a commercial cleaner but I am thinking they will not help. rats.
ugh, what a drag. anyone have a rough idea on how much to replace the CD drive? it is almost comical to me really.
thanks,
jim
Old 08-20-2004, 07:29 AM   #9 (permalink)
shiraz's Avatar
Date registered: Aug 2004
Vehicle: MB E430 Avantgarde
I had the same problem a few weeks back. I did a system restore and everything went to German. Of course, I couldn't change that because you need to read the language setting from your system disc!
The local MB dealers sent me to a company specialising in Merc and BMW audio equipment. It turns out that the laser assembly on the CD drive was faulty. This job turned out to be about R1000 (US$150) but was fortunately covered by my MB maintenance plan.
shiraz is offline   Reply With Quote
