Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
Old 06-12-2004, 11:27 AM   #1 (permalink)
Date registered: Jun 2004
Volume level changes
Hello, I'm a newbie here.
The volume in my 1995 c280 tends to get louder by about one level when I increase speed. It will stay at that level for a while and then may just drop back down one level. the occurence of the increase and decrease is varable and does not happen every time I increase or decrease speed. Is this one of those speed sensitive radios Mercedes uses? If so shoulden't it increase decrease regularly as i increase decrease speed? Can I by pass this feature?
Thanks,
Graydog
Graydog is offline   Reply With Quote
Old 06-13-2004, 08:15 AM   #2 (permalink)
Date registered: Jan 2004
Vehicle: 1991 230E w124
RE: Volume level changes
From your description, it seems that your radio does have a speed-dependant volume control feature. This is usually bypassable. What model is your radio? This will help to determine how to bypass it? If you don't know the model, send a photo.
Usually to bypass it, the speed-dependant volume control wire is disconnected from the radio. I'm not sure if there were any radios that had the enable/disable feature built-in to the settings.
HafizMk is offline   Reply With Quote
Old 06-14-2004, 01:40 AM   #3 (permalink)
Storm's Avatar
As far as I know there have not been any factory MB stereos with a feature to switch off the Speed sensetive volume auto leveling.
Storm is offline   Reply With Quote
Old 06-18-2004, 05:45 PM   #4 (permalink)
Thanks for the answer. I will check and post the model of the radio tomorrow. All I know is that it is a Bose system.
Old 11-16-2004, 07:34 AM   #5 (permalink)
Date registered: Nov 2004
Hi Greydog...
I am a new owner of a 2002 ML-320 that has EXACTLY the volume "problem" you are describing, and wish to disable it. Have you had any luck (on your own or at a dealer)?
Thanks!
SatDoug is offline   Reply With Quote
Old 11-16-2004, 03:37 PM   #6 (permalink)
Date registered: Mar 2004
Like most things on a Benz, the dealer can disable this feature.
Cheers,
Steve Urban
SteveUrban is offline   Reply With Quote
