Airmatic Failure Pictures and Details - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-21-2010, 08:41 PM Thread Starter
Supporting Vendor
Arnott Inc.'s Avatar
Date registered: Oct 2009
Vehicle: Testing Cars ('01 S430), ('04 CL500), ('05 S500), ('05 SL500), ('07 S550), ('09 E550), ('10 GL450)
Ok everyone I finally found some time to put together the pictures and details of the Mercedes Airmatic shock assembly. I did not include the pictures showing the epoxy cracking issue around the top section of the shock. I know there is some older post showing the problem and solutions for that repair. I think it would be a great idea for someone to find that post and copy it into this thread. That way we can try to keep as many air suspension posts in this thread as possible. This will allow everyone to see questions and solutions for repairing their air suspension without searching all over the forums. We are also finalizing remanufacturing the ABC shocks at the time of this publication. Once that process is complete, I will do the same thing and post pictures showing everyone the failure points to look for when diagnosing the ABC suspension systems. I will also post pictures and details on our coil spring replacement system due to launch in another couple months. If anyone has any questions, please feel free to e-mail me directly at adam@arnottinc.com.
Thanks everyone!
Adam
1. The first picture shows you an example of a worn lower dust cover on an Airmatic shock. Once you start to see this on your shock, the end is near.
2. The next image shows a typical worn upper mount removed from a shock with around 80,000 to 100,000 miles. A worn mount will contribute to many unwanted problems with your suspension.
3. One common failure of an Airmatic shock is the lower piston seal. The lower seal is designed to flex and absorb vibrations from the road. Oil, dirt, and heat degrade the rubber over time causing the lower seal to fail. This picture shows an extreme failure of the lower seal. It’s not a bad idea to lift your vehicle and inspect this seal around every 20K miles or so.
4. Now we are moving into the air spring side of the assembly. This is the part of the shock you cannot see because it’s located behind the silver aluminum section of the shock. In order to remanufacture the shock we have to machine off the can to replace the air spring. The can is then powder coated and reassembled back onto the shock during the reassembly process later. This picture gives you a sneak peek of the rubber bladder behind the can. You can see from this first picture a typical worn out air spring bladder. The hole in the air spring is the reason it failed.
5. Now let’s take a look at the inside of the air spring's bladder. In order to see this we have cut the rubber bag open with a knife to expose the wear spots. Once inside, you can see the vertical wear spots that happen over time. Because the air spring is made from a very thin single nylon cord layer the vertical weak spots or lines you can see on the air spring's surface will eventually pop through causing a complete failure.
6. The last picture in the group shows the new air spring we use in the remanufacturing process. Unlike the OE bladder, we use a 2 ply design that prevents vertical wear points. You can see from the picture our air spring bladder is over 2 times thicker than the original bladder.
Arnott Inc.
100 Sea Ray Drive
MerrittIsland, FL 32953
www.arnottinc.com
www.arnotteurope.com
www.arnottcanada.com
Arnott Inc. is offline
post #2 of 6 (permalink) Old 02-05-2014, 10:52 PM
Date registered: Jul 2012
Vehicle: 2000 ML320, 2008 ML63
Since the bladder was worn out, the shocks must be very worn out. Did you fix those and better yet replace them as you did with the air spring?
GoldML63AMG is offline
post #3 of 6 (permalink) Old 05-28-2014, 08:07 AM
Date registered: May 2013
some chinese eBay Sellers have parts that look identical to Arnott's parts. Made me wondering.
adobian is offline
post #4 of 6 (permalink) Old 06-06-2014, 10:54 AM
tewfiks's Avatar
Vehicle: Many MBZ, Couple of 911s, couple of pick ups
Quoted: 49 Post(s)
Post
I have a replacement front airmatic shock for my 2007 GL320. Was replaced about six months ago after noticing the affected corner sagging. The GL no longer sags but the shock is giving a cluncking sound when going over bumps now. Ideas?
Sherif Tewfik
70 280 SE/cab
72 280SE 4.5
78 6.9
80 280 SL
88 300 CE
94 E500
95 E420
95 E320 Cab
95 E320 Wagon
05 E55 Wagon
07 GL320 CDI
11 E350 4matic Wagon
tewfiks is offline
post #5 of 6 (permalink) Old 06-06-2014, 11:02 AM
YES I DO HAVE AN IDEA! Same exact thing happened to me! This drove me NUTS. Thought it was sway bar links which replaced TWICE cause the first time I thought it was cause it was aftermarket sway links, then tried OEM. You have to, unfortunately, call Arnott and have them ship you replacement shock because IT IS the shock. You have to try to see which side is it that's clunking and when you get the replacement swap that side. In MY case I had to replace BOTH sides because they were both clunking and after swapping many parts found out it was the NEW Arnott shocks. At least Arnott doesn't give you trouble with replacements but you do have to swallow the labor cost...in my case I did it myself so just cost me a weekend.
post #6 of 6 (permalink) Old 06-28-2014, 03:18 PM
tewfiks's Avatar
Quoted: 49 Post(s)
Post
Thanks for the advice
Sherif Tewfik
70 280 SE/cab
72 280SE 4.5
78 6.9
80 280 SL
88 300 CE
94 E500
95 E420
95 E320 Cab
95 E320 Wagon
05 E55 Wagon
07 GL320 CDI
tewfiks is offline
  Mercedes-Benz Forum > Supporting Vendors > Arnott Inc.
    Another S-class airmatic failure oneslackr W220 S-Class 6 10-21-2012 03:01 PM
    Airmatic Failure in pics mobilusa W220 S-Class 13 01-23-2012 03:44 PM
    Airmatic failure - 'Visit workshop' jjl1 W164 M-Class 63 02-04-2011 05:49 AM
    Airmatic failure and Cold Weather chibenz W220 S-Class 10 02-06-2009 12:57 AM
    E500 Airmatic Failure PaluzTV W211 E-Class 18 07-20-2007 12:38 AM
