Electronic Ignition Key Does Not Work - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 07-01-2011, 07:31 AM Thread Starter
harb's Avatar
Date registered: Nov 2004
Vehicle: 2000 E320
Hello - I have a 2000 E320 with an electronic ignition key. Yesterday, I stopped the car and tried to get back in it to start it and the key won't turn. The car battery is fine. I changed the electronic ignition (FOB) key batteries and still had the same problem. They key would not even lock or unlock the doors.
Finally, I had to call a taxi to go home and get the spare key and the car started just fine. What would cause the key to break? and how can I fix it?
Thank you.
Tony Harb
2000 E320
1990 300E
1986 380SE
1982 280SE
1977 280S
harb is offline
post #2 of 7 (permalink) Old 07-01-2011, 09:24 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 15 Post(s)
They do sometimes die, which it sounds as though yours did. And unless you're an electrical guru, you won't be able to fix it (you could take it apart to see, there is a chip that can come "unsoldered" and with the right equipment and expertise can be resoldered). Otherwise the usual "fix" is replacement. Call all of your local stealers and see who has the best price for a replacement.
Good luck.
Check Codes is offline
post #3 of 7 (permalink) Old 07-01-2011, 12:37 PM Thread Starter
harb's Avatar
Vehicle: 2000 E320
I opened the FOB case and removed a small white plastic PCB retainer (very gently!). At that point, the PCB slid right out. I visually inspected all components but could not see any loose solder joints or anything unusual. I cleaned it and put it back together but still have the same problem. I read somewhere that they keys are preset to a certain number of starts, after which they stop working (something like 80,000 starts). That seems like a lot of starts! and unlikely to be my problem, I think.
Has someone ever repaired the FOB PCB? And if so, what normally fails on the board?
I am trying everything I can before I have to cough up the big bucks for a new key, not to mention the satisfaction recognized from fixing it myself!
Tony Harb
2000 E320
1990 300E
1986 380SE
1982 280SE
1977 280S
harb is offline
post #4 of 7 (permalink) Old 07-01-2011, 01:13 PM
SHAUNE55's Avatar
Date registered: Aug 2010
Vehicle: 2001 E55 AMG
If you search the threads on here there is a member who repairs key fobs. I think it's darknight, not 100% on that though.
SHAUNE55 is offline
post #5 of 7 (permalink) Old 07-02-2011, 07:54 AM
~BANNED~
Date registered: Jun 2010
Vehicle: 2004 CLK500
My feeling exactly, when I figured out how to beat the stealer.
You need to look under a microscopes to see defects at components level.
Send me a pm, I might be able to help.
drkknght is offline
post #6 of 7 (permalink) Old 07-04-2011, 08:58 AM
Date registered: Sep 2010
could a faulty key fob also present a no start/start/delayed start? my key upon being inserted is ack'd by the system and does physically turn, however, it has a delayed start, sometimes starts literally on its own, while in the start position, or just wont start at all. when it does start it turns right over nicely, lately this has been very rare. could the key itself, although, it turns and has system ack'd cause a series of no starts/partial starts/delayed starts? thank you in advance!
all the best
1998 E430 Sport special addition. 250,000 plus original miles. K&N drop in air filter, Mobil 1 0w-40/(Lubro moly anti-engine friction), Mann Fleece oil filter, Shell V-Power, fuels, Mobil 1 75W-90, Valvoline Dexron Max-lfie ATF, Lubeguard (red bottle)
98e430sport is offline
post #7 of 7 (permalink) Old 07-05-2011, 08:58 AM
~BANNED~
You might want to clean the lense at the tip of the key with alcohol for cleaner signals, less interference.
drkknght is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > AMG W210 E50 , AMG E55
User Tag List
electronic ignition dsan Vintage Mercedes-Benz 7 07-09-2010 09:03 AM
EIS Electronic Ignition Switch (I think)!!!!!!!HELP!!! ekasparov W215 CL Class 3 12-31-2009 05:51 PM
Electronic Ignition Key mishael W202 C-Class 4 12-15-2007 10:51 AM
Need Help on Electronic Ignition Modification Work ESOOO W116 S, SE, SEL, SD Class 3 01-10-2007 11:10 PM
Electronic ignition - any advantage? Gazolba Vintage Mercedes-Benz 4 10-11-2006 08:04 PM
