Engine light - 300 & 304 code? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-21-2009, 03:29 PM Thread Starter
leomd's Avatar
Date registered: Jan 2007
Vehicle: 2000 E55 / 2002 G500 / 1998 Range Rover
Under WOT I got a blinking engine light - after investigating I got a 300 code (misfire) and a 304 code (cylinder 4 misfire code) which is scaring me. I reset the codes with my obd2 tool and havn't seen any other issues. Could this be an issue caused by a faulty o2 sensor or the notorious maf? I have about 48k miles and the engine seems to run fine but power is down. Any ideas will be helpful - thanks
2000 Silver E55
2002 Silver G500
2003 White G55
leomd is offline
post #2 of 4 (permalink) Old 09-22-2009, 11:21 AM
ruBENZ_00E55's Avatar
Date registered: Mar 2006
Vehicle: 2000 E55 AMG
* Misfire damages TWC (THREE WAY CATALYTIC CONVERTOR); indicates a misfire
* Misfire cylinder 4 damages TWC (THREE WAY CATALYTIC CONVERTOR); pinpoints the misfire.
It seems to me, that your cats are taking a beating if not on there way out. O2 sensor could be the culprit. Depending on your MAF history (OEM, replaced or cleaned), it may also be the MAF. BTW, my MAF failed at 42K mi. Nonetheless, I would have a professional look at it before you completely damage your catalytic converter(s). Good luck.
ruBENZ_00E55 is offline
post #3 of 4 (permalink) Old 09-22-2009, 12:14 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 34 Post(s)
I doubt it's the MAF (both banks would have problems) or the O2 sensor (it wouldn't be just one cylinder. A single instance of misfire won't hurt anything, the ECU likely shut down the offending cylinder (the flashing light says Hey, shut down so I can reset) to preclude damaging the cat, too.
I'd suggest getting it on a regular scanner that can give you some real-time feedback and LTFT data. If the LTFT data look good, you can further discount the MAF.
If the scanner can isolate cylinders, you may be able to truly pinpoint the issue.
I'd probably be tempted to take it to a good indy that has an appropriate setup (doesn't have to be the SDS) and can help you diagnose it. Either that or start throwing parts at it, which will get expensive, frustrating and time-consuming in a big hurry.
Check Codes is offline
post #4 of 4 (permalink) Old 10-07-2009, 07:20 AM
Date registered: Sep 2002
Vehicle: 2001 E55
For the rest of us, LTFT data? I have the AutoTap OBD II program which hooks up and runs through my laptop. It reads and records real time data (OBD II requirements only - not the double secret password MB star data). Anyway, without knowing what the normal parameters are for the given readings - the data doesn't mean much. Is the 'normal range' data available anywhere? Great thread this one, thanks. BTW '01 E55 20,800 miles.
Gary R. Watkins is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > AMG W210 E50 , AMG E55
User Tag List
Check engine light on, code P0200 on 97 E 300 diesel crid W210 E-Class 28 05-07-2014 10:45 AM
Check engine light – Code 4 (on plug itself – red light on diag. mod.) & Pin 14 CC/ETA gives Cod rwogs W124 E,CE,D,TD Class 1 01-16-2009 12:07 PM
Engine doesn't start - P0170, 173, 300, 301, 304 mirceap W208 CLK Class 1 07-04-2008 02:43 AM
99 E320 errors 204, 300 & 304 diehard_dude W210 E-Class 0 01-02-2007 04:02 PM
Check Engine: Code 300, 302, 304 omeyhomey AMG W210 E50 , AMG E55 5 09-13-2006 02:42 PM
