After Battery Pull - How long until the car can pass emissions? Gather info etc - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-13-2009, 10:55 AM Thread Starter
Date registered: Jan 2009
Vehicle: 2000 e55 White.
Ok - I read back to 2007 and cant find the answer
I ran sea foam in the car last night.. through a vacuum line which sets off a CEL... (of course) so rather then wait for it to reset (I had an emissions test to do today) I took board advice and pulled negative and then started up... CEL gone.. however it wont pass now since the car hasnt gathered enough data to pass to the DMV.
Anyone know how many miles you must drive to reactivate the sensors etc?
Thanks
Jon
- last small question- whats the best way to troubleshoot the leaking seat issue? I checked the pump.. its blowing for about 1 minute before it stops.. then the seats deflate. i can hear a small whoosh from the passengers seat... the controls function during that minute that they inflate... then they no longer function after that point.
molitar is offline
post #2 of 2 (permalink) Old 02-13-2009, 11:13 AM Thread Starter
Well to answer my own question- i dont know if its ok - but i found the answer here:
Failed NJ State Inspection for ODBII/Emissions Failure - MBWorld.org Forums
after pulling battery it takes up to 45 minutes of driving for the sensors to gather enough data to give an "ok" code.
molitar is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > AMG W210 E50 , AMG E55
User Tag List
car cranks way too long to start, battery is ok. possible cause? ProV1x W210 E-Class 8 05-23-2010 01:55 PM
Runs Great / Won't Pass Emissions Test sammywater W201 190 Class 8 06-11-2008 02:08 PM
Need Help to Pass Emissions! Cat Problem? W202 C220 realog General Mercedes-Benz 3 01-06-2008 02:04 PM
exhaust header options that will pass emissions Yao W126 S,SE,SEC,SEL,SD,SDL Class 1 10-19-2006 01:11 PM
How do W123 diesels pass emissions? Rickthecoinman W123 E,CE,D,CD,TD,TE Class 10 02-19-2004 03:20 PM
