steering wheel makes groaning noise - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 03-17-2007, 05:17 PM Thread Starter
ProV1x's Avatar
Date registered: Jul 2006
Vehicle: E55 ///AMG
hi all, just picked up my 01 E55. just awesome. but i have a few issues, one of which:
when i turn the steering wheel, either direction, at low speeds it makes 'groaning' noise. like groaning or rubber squeaking kinda noise. what is this?
Gone but not forgotten:
2003 Honda S2000
1999 BMW 540i sport
1995 BMW M3
ProV1x is offline
post #2 of 14 (permalink) Old 03-17-2007, 06:35 PM
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Quoted: 5 Post(s)
Check your Serpentive Belt.
JOE55 is offline
post #3 of 14 (permalink) Old 10-18-2007, 06:18 PM
Date registered: Oct 2007
I had the same problem and took authorised benz workshop 2 weeks to look for the problem. Actually , it is simple problem and dont let them changed the whole steering shaft(expensive) . The noise is from radial sealing ring on the steering gear control head. The rings is black in color, located inside the bar located bwtween the 2 front wheel. the spare parts are very cheap but labor intensive. You need a expert to repair this and the ATF oil need to be drained first. It is not as easy as just to open the steering wheel inside the cabin and spray lubricants.
MB IDOL
MB-IDOL is offline
post #4 of 14 (permalink) Old 10-31-2007, 03:55 PM
Ed Austin's Avatar
Vehicle: '01 E55
I have same noise
I have the same groaning noise in the steering wheel that the original post describes. Also, it just started making a squeaking noise in the front of the engine (somewhere on the front driver's side of the engine). Possible the serpentine belt or one of the pulleys on the belt.
Joe55, why did you suggest the belt? Is the groaning in the steering wheel a common symptom of a worn belt?
Ed Austin is offline
post #5 of 14 (permalink) Old 11-02-2007, 08:51 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 26 Post(s)
Hi, Ed. This is a relatively common issue with the W210. There are a couple of TSBs out on it depending on which issue is causing the noise. One is relatively quick, simple and cheap, the other requires removing the rack and replacing a part in the steering box if memory serves correctly (my car had both done under warranty, they always do the cheap one first, if that doesn't resolve it then the big $$ one, it's big dollars because of the labor). If your warranty is expired these are wholly on your dime as well.
I can't say why Joe suggested the serpentine belt, but he's since had his rack replaced, I think in part to chase the noise he was having.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #6 of 14 (permalink) Old 11-02-2007, 09:06 AM
peter_02AMG's Avatar
Date registered: Jun 2007
Vehicle: 2007 E63 / 2008 997TT / 2002 E55 AMG (SOLD)
MB IDOL
Why does the ATF oil need to be drained?? Stering wheel have no direction connection to the transmission.
I having the same noise in my stering wheel. now it getting louder because the weather is getting colder. really annoying.
peter_02AMG is offline
post #7 of 14 (permalink) Old 11-02-2007, 09:24 AM
Ed Austin's Avatar
Vehicle: '01 E55
Thanks, Greg, for the input. I'm getting a new serpentine belt and belt tensioner in the mail today. I diagnosed the belt tensioner as the culprit of the chirping noise with a stethescope. I'll put those in this weekend and (hopefully) take care of the noise in the engine compartment.
If I still have the noise in the steering wheel, I'll try the "cheap" fix first. I think you are referring to the TSB that shows how to champfer the edges of the sterring boot and the nylon seal ring.
post #8 of 14 (permalink) Old 11-04-2007, 07:48 AM
Date registered: Jan 2007
Vehicle: 2005 S500 4matic Sport Designo
Quoted: 43 Post(s)
MB IDOL
Can you elaborate on what your tech did.
I have this same noise, and Id prefer not to replace the rack if at all possible since it doesn't leak.
If you don't mind me asking, what did you pay for the repair and do you have the part numbers?
Quadcammer is offline
post #9 of 14 (permalink) Old 11-09-2007, 06:59 PM
Quoted: 26 Post(s)
Hey, folks.
I knew I'd seen the details somewhere, while editing the DIY sticky in the 210 forum I came across it, supplied by reyna7. It's a pdf, so if you don't have Acrobat reader installed, then when you come back from your home planet go ahead and take care of that, then you can view it.
Greg
http://www.benzworld.org/forums/atta...factsept04.pdf - PDF Version
Adobe's Free Acrobat reader can be downloaded by following the steps starting here: Adobe - Adobe Reader Download - All versions
post #10 of 14 (permalink) Old 11-10-2007, 01:25 AM
JOE55's Avatar
Vehicle: E55 ///AMG
Quoted: 5 Post(s)
Greg
This ia before my rack got replaced, anyway the noise is gone.
JOE55 is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > AMG W210 E50 , AMG E55
User Tag List
E320 Steering wheel makes a scraping noise Henrick W210 E-Class 12 01-29-2011 09:31 PM
Groaning steering wheel james54 W210 E-Class 1 10-23-2006 04:03 PM
Groaning steering wheel.... fgwinn R171 SLK Class 3 02-13-2005 08:22 AM
Stiff & Groaning Steering Wheel lemmyb W124 E,CE,D,TD Class 1 08-31-2004 02:37 PM
Steering wheel groaning (32)... Marc32 R170 SLK Class 5 09-10-2001 06:52 AM
